Hi
I have problem with my Spider Compatible card bought from here
http://www.amibay.com/showthread.php...1xUSB-internal
in os3.9 its working perfect
but in 4.1
poseidon says that he cant load poseidon.prefs file
in 4.1 we dont have env or envarc directory
i made it my self an reinstall poseidon
but no pref file in again
any idea ?
Gokce
OS41 FE with Spider compatible pci
- MichaelMerkel
Re: OS41 FE with Spider compatible pci
what do you mean with "in 4.1 we dont have env or envarc directory"?gbozkurt wrote:Hi
but in 4.1
envarc: is an assign pointing to "SYS:Prefs/Env-Archive". you can put your files there.
(although i wonder why poseidons settings are stored in the SYS folder. this is for system components...)
regards...
michael
When i install the poseidon software, i'm changing nothing..
I'm accepting all the questions and choices "yes", in 3.9 and the sameway in 4.1
3.9 ok but why some problems in 4.1 ?
Is it possible that it is trying to install something in WBStartup, which obviously does not exist in AmigaOS 4.1?
ENVARC: and ENV: definitely are both available under 4.1.
Simon
Simon
Is Spider USB compatible with AmigaOS4.1? I was thinking it will not work at all.
