openSUSE Tumbleweed
openSUSE Tumbleweed
I managed to install and run succesfully openSUSE Tumbleweed in my X5000 :-). It went quite straightforwardly, thanks to the ready made disk image and instructions kindly provided by Christian and Luigi in the X1000-Linux board (http://forum.hyperion-entertainment.biz ... 6&start=19). I tested it with v. 4.9.39 Kernel.
Tumbleweed seemed to work fairly well at first glance... The only major problem I noticed was that some system parts were extremely slow, especially the prefs settings under Yast. So, still a lot of work for the developers...
Did not yet try to update it, I have to wait untill I get a faster internet connection.
Re: openSUSE Tumbleweed
Roland wrote:I managed to install and run succesfully openSUSE Tumbleweed in my X5000 :-). It went quite straightforwardly, thanks to the ready made disk image and instructions kindly provided by Christian and Luigi in the X1000-Linux board (http://forum.hyperion-entertainment.biz ... 6&start=19). I tested it with v. 4.9.39 Kernel.
Excellent! Well done! :-)
I created with dd an img of my openSUSE Tumbleweed 20170924 PPC64 installation today.
Be aware, that openSUSE is experimental and isn't supported. openSUSE Tumbleweed is alpha software! It's only for testing and tinkering!
Download: openSUSE_Tumbleweed_20170924_ppc64.img.tar.gz
Users:
root (password "amigaone")
If the automatic network configuration of openSUSE doesn't work then it is possible to configure the network manually. I created some network configuration instructions for openSUSE today. Link: forum.hyperion-entertainment.biz
If you want to see the splash screen then add splash=silent to the boot arguments.
Splash screen of openSUSE Tumbleweed:
openSUSE Tumbleweed 20170924 PPC64 on an AmigaOne X5000:
openSUSE Tumbleweed 20170924 PPC64 on an AmigaOne X1000:
Have a lot of fun with openSUSE Tumbleweed! :-)
xeno74 wrote: I created with dd an img of my openSUSE Tumbleweed 20170924 PPC64 installation today.
Great news, thank you! Does this new image also include latest updates (compared to the one you had in X1000 board)? When I tested the older version, I was not able to download hardly any updates, due to missing dependencies...
Unfortunately I cannot now do any testing as my Cyrus+ was sent a couple of moths ago for repair... (the realtime clock issue).
I'm out of news of it for several weeks, don't know if it ever returns to me :-(.
Roland wrote: Great news, thank you! Does this new image also include latest updates (compared to the one you had in X1000 board)?
Yes, it includes the latest updates. :-)
Roland wrote: Unfortunately I cannot now do any testing as my Cyrus+ was sent a couple of moths ago for repair... (the realtime clock issue).
It's OK. Never mind.
I have recently released an update of the openSUSE Tumbleweed 20170924 PPC64 img.
  • Network configuration issue solved
  • YaST updated
Download: openSUSE_Tumbleweed_20170924-2_ppc64.img.tar.gz
SSH ACCESS
If you can't login to openSUSE Tumbleweed via SSH then deactivate the line PasswordAuthentication no with a hashtag (#) in the config file /etc/ssh/sshd_config. After that please restart the sshd service with rcsshd restart.
openSUSE Tumbleweed 20170924 PowerPC64 with a virtual S.u.S.E. Linux 5.0 x86 machine on an AmigaOne X5000. FVWM2 from 1997 and from 2017 together.
I installed and tinkered with this for hours. It is quite an impressive version of Linux and full of potential. The install seems to be quite robust and stable with everything working fine. A few little tricks required like setting up network device and repositories. The only real drawback is the limited packages available (including limited codec support) otherwise this would make an ideal complimentary AOS4 install on an X1000 or X5000.
allan
acefnq wrote:Christian
allan
Hi Allan,
Many thanks for testing openSUSE! :-) Did you copy the openSUSE image to a partition or did you install it with the official installation program?
