Hmm... maybe the lockups will "wait" several minutes then...
I didnt notice any lockups here, as long as I dont do any network/usb transfers.
I recheck now, and I do several actions with "more than filled up" RAM Disk (256MB physical RAM, RAM Disk holding a mere 400MB of data), still no lockups. Even compiling a small project using the latest CodeBench works fine (although a bit slow
). Ok, CodeBench has problems with low memory condition, too ("corruption of projects dictionary" requester, Grim on end), but its beta...
Even Wordworth7 is running fine, including document loading and printing (!) via a1parallel.device, although all the conditions above still apply (I do realtime testing atm., using a windows machine to post here). Added MUI-OWB (without retrieving any data from my network, that is), system is still running stable. I quit all the programs now, and the pager/memory subsystem gives back free 80MB RAM and system is still running fine. Seems that it works ok. I do another test atm., running GLQuake... still RAM Disk is filled with more data than physical memory available, Quake runs fine. Playing MP3 from a directory located in RAM Disk works, too.
Well, I dont think that the lockups I experienced originate from the pager itself
As Im no betatester yet, I dont know much about problems of the pager at all, but for me it works amazingly good (and quite fast, program startup times are near to normal, just a bit slower). Except for network traffic, which will cause _reproducable_ lockups with low memory condition. If my machine would have been a bit more stable with IDE (onboard), I would check for the network device (onboard) by replacing it with a Realtek one, but as IDE (onboard) is _utterly_ unstable, I dont think that it would help much in finding the cause of the lockups... thats why I asked for other people trying the pager with their machines (ideally their machines should be no MicroA1).
Maybe I should add that first I experienced problems with the OS itself, too. But this was due to incorrect preparation of my SWAP partition. After I rechecked and fixed it, the pager works fine and the system is working quite good.
Edit: Oh... forgot mentioning that I use a SII0680 as the onboard-IDE replacement.
