I just added a vertical gradient slider. To me the values seems backwards: the bottom should be 0, the top should be 100. But it is the opposite. If it were a volume control, the top is max volume, not mute. Even the colors are backwards.
Is there a formula, or function, to reverse the values?
If at top 0->100.
If at 75% 25->75
If at 50% 50->50
If at 25% 75->25
If at bottom 100->0
SliderGadget has SLIDER_Invert, looks like gradient could use that, too.
*EDIT*
Reverse the value: 100-((100*GradLevel)/100)
GradientSlider values
- broadblues
Re: GradientSlider values
It's a gradient slider, the actual value is arbitrary, when used in cnonjuntion withy a colour wheel, you allow the colour wheel to setup the values, and the brrightest colour is at the top.I just added a vertical gradient slider. To me the values seems backwards: the bottom should be 0, the top should be 100.
It's not a volume knob though is it?But it is the opposite. If it were a volume control, the top is max volume, not mute.
Only because you put them backwards.Even the colors are backwards.
Seriously?Is there a formula, or function, to reverse the values?
If at top 0->100.
If at 75% 25->75
If at 50% 50->50
If at 25% 75->25
If at bottom 100->0
If a value varies from 0 to range, to convert it to range to 0 just do value = range - value.
Whilst it could be added the gradient is picking arbitrary values that represent a colour, whereas the silder gadget is picking the actual values, and, more to the point, can display those values
There is no need for the reverse state in the Gradient, the develeoper just needs to do some trival maths.
- broadblues
No that's wrong*EDIT*
If you want avalue from 0 to 100 just set GRAD_MaxVal to 100
The the inverted result is 100 - GradLevel
If for some reason you need maximum resolution (as I do in my SketchBlock colour window which generates floating point colour (albeit with only16 bits of precision against the max of 24)
Then
Non iverted
((float)GradLevel * 100.0) / (float)0xFFFF
Inverted
(100.0 * (float)(0xFFFF - GradLevel) ) / (float)0xFFFF
Be carefult of the brackets
Note to self: don't try to program at work when not enough time; you word your questions poorly.
Thanks. Getting it up and running.
