Open rexxsyslib.library
JosDuchIt
Post by JosDuchIt »
The following and similar code opens the given library (with or without the _NOBLOBALIFACE_
//#define _NOGLOBALIFACE_
#define __USE_INLINE__
#define MINVERSION  52
#include <stdio.h>
#include <proto/asl.h>
#include <proto/exec.h>
#include <exec/types.h>
#include <exec/exec.h>
#include <exec/execbase.h>
#include <interfaces/exec.h>
struct Library *AslBase;
struct AslIFace *IAsl;
int main ()
AslBase = OpenLibrary ("asl.library",MINVERSION);
if (AslBase)
	IAsl = (APTR)GetInterface(AslBase, "main", 1L, NULL);
else printf("no AslBase\n");
printf("hello\n");
if (AslBase)	 	CloseLibrary (AslBase); //changed
	if (IAsl)		DropInterface( (struct Interface *) IAsl);
the code following does not open the rexxsyslib.library (with or without the _NOGLOBALIFACE_
the Base and IFace defintione are taken from <proto/rexxsyslib.h>
#include <stdio.h>
#include <proto/rexxsyslib.h>
struct Library *RexxSysBase;
struct RexxSysIFace *IRexxSys;
int main ()
RexxSysBase = OpenLibrary ("rexxsyslib.library",MINVERSION);  //changed
if (RexxSysBase)
	IRexxSys = (APTR)GetInterface(RexxSysBase, "main", 1L, NULL); //changed
else printf("no RexxSysBase\n");
printf("hello\n");
if (RexxSysBase)	 	CloseLibrary (RexxSysBase); //changed
	if (IRexxSys)		DropInterface( (struct Interface *) IRexxSys);
What is happening here?
Re: Open rexxsyslib.library
rexxsyslib.library is still 68k, make sure you have rexxsyslib.l.main in libs:
JosDuchIt
Post by JosDuchIt »
i do have it.
Does the code works for you ?
i do have it.
It does after I change line 3 to:
#define MINVERSION 45
JosDuchIt
Post by JosDuchIt »
Thanks a lot.
Meanwhile, hitting my head on the table
