Sam460ex 4.12.0 kernel .
(Boot via U-boot shell from internal SD card,USB thumb drive or tftp server).
I have started to boot from the Sam460ex's internal SD card with a class 4 SD card .
SD Card or thumb drive partition must be ext2 or Ext3 format .
The default AmigaOS script to set the U-boot boot variable uses the 3rd partition of the SD card or USB thumb drive for loading the kernel and dtb file .
https://drive.google.com/open?id=0BxoZd ... FVVZ1VPaTA
Kernel 4.12
Kernel 4.12
Re: Kernel 4.12
Sam460ex 4.12.2 kernel .
https://drive.google.com/open?id=0BxoZd ... TlOSTFlX0k
Re: Kernel 4.12
Sam460ex 4.12.3 kernel .
https://drive.google.com/open?id=0BxoZd ... k5vNlJvUE0
Re: Kernel 4.12
Sam460ex 4.12.4 kernel .
https://drive.google.com/open?id=0BxoZd ... llDbDhXSWc
Re: Kernel 4.12
Sam460ex 4.12.5 kernel .
https://drive.google.com/open?id=0BxoZd ... jR1aEFjRVE
Re: Kernel 4.12
Sam460ex 4.12.6 kernel .
https://drive.google.com/open?id=0BxoZd ... TB1aWNyaDg
Re: Kernel 4.12
Sam460ex 4.12.8 kernel .
https://drive.google.com/open?id=0BxoZd ... GxwQ2tQT1k
