Newlib rounding bug with function lroundf()
The Newlib lroundf() function rounds all numbers between 1.0 and -1.0 to 0. Only numbers with an absolute value less than 0.5 should be rounded to 0. clib2 rounds numbers between 1.0 and -1.0 correctly.
Here is a small program that demonstrates the error when compiled and executed:
#include <proto/exec.h>
#include <proto/dos.h>
#include <math.h>
#include <stdio.h>
int main()
	float x = 0.9;
	float y = -0.9;
	int a = 0;
	int b = 0;
	a = lroundf(x);
	b = lroundf(y);
	printf("x = %f  &  a = %d\n", x, a);
	printf("y = %f  &  b = %d\n", y, b);
	return 0;
The output when the above program (named 'test') is compiled with newlib & executed:
6.Ram_Disk:> test
x = 0.900000 & a = 0
y = -0.900000 & b =0
The output when the above program (named 'test') is compiled with clib2 & executed:
6.Ram_Disk:> test
x = 0.900000 & a = 1
y = -0.900000 & b = -1
Can someone compile & test the above program, confirm the erronious result and file a bug report to get this fixed.
Re: Newlib rounding bug with function lroundf()
Curiously it only applies to numbers less than 1.0 so nothing as simple as the "rounding direction" being different. (though the spec does say these functionjs ignore the rounding direction anyway).
broadblues wrote:Curiously it only applies to numbers less than 1.0 so nothing as simple as the "rounding direction" being different. (though the spec does say these functionjs ignore the rounding direction anyway).
It does ignore the rounding direction; which is why I should have said it rounds numbers between 0 & 1.0 and between 0 & -1.0 incorrectly. I've edited my original post to reflect that fact. Thanks for pointing it out. I just hope someone can file a bug report now.
Should be fixed in newlib 53.43
broadblues wrote:Should be fixed in newlib 53.43
Thanks.
