Amiga 4.1 install on a PC
As a novice, I would like some helps installing Amiga 4.1 on my PC. I originally purchased Amiga forever in 2012. They say I had to upgrade to it to get Amiga4.1 on a pic. So I did. It gave me what's called Amiga 7 forever. I'm getting nowhere. Am I using the correct software? Grateful to anyone who can assist.
Re: Amiga 4.1 install on a PC
Hi Kevin,
There are plenty of people who know more about emulation than I do, but as I understand it, Amiga Forever is a 68K emulator that emulates only OS 3.x, not OS 4.x (which is Power PC code).
I believe that the "A.L.I.C.E." kit from A-Eon runs OS 4.1 under WinUAE emulation, maybe that is what you need (WinUAE, that is).
I've never done it myself yet but here is some info:kevenryn wrote:As a novice, I would like some helps installing Amiga 4.1 on my PC. I originally purchased Amiga forever in 2012. They say I had to upgrade to it to get Amiga4.1 on a pic. So I did. It gave me what's called Amiga 7 forever. I'm getting nowhere. Am I using the correct software? Grateful to anyone who can assist.
http://amiga.net.pl/index.php?lng=eng&kwt=10010&tms=64
http://amigax1000.blogspot.no/2015/03/a ... -2529.html
Check the 'Flower Pot went Linux' topic at Amigans.net
You can use FlowerPot (~10€): https://www.amikit.amiga.sk/
You can indeed use Amiga Forever to load and run OS4.1
The latest version has PPC support built in.
