DataTypes Descriptors...
Belxjander
Post by Belxjander »
Has everyone made these generally by hand themselves?
Or is there a standard toolkit for making them?
Re: DataTypes Descriptors...
Post by thomasrapp »
Belxjander wrote:Has everyone made these generally by hand themselves?
It would be nice to have them defined somewhere in the SDK.
I tend to use the old Commodore tool "dtdesc" as it's so easy to use.
Maybe this can be added to the SDK?
Belxjander
Chris: I've been looking for that actually... I remember putting it into "Sys:Prefs/" on my older 68K systems
as a DataTypes Preferences Tool...
I definitely need to find a new copy of that (perhaps it can be recompiled/ported with the newer SDK materials?)
It'd be a definite improvement towards DataTypes becoming more the basic standard in using preexisting data on disk at least.
wghich is something I am definitely playing with expanding at the moment
Belxjander wrote:Chris: I've been looking for that actually...
It's on the old DevCDs, I don't know if there's another source.
trixie
Post by trixie »
Belxjander wrote:perhaps it can be recompiled/ported with the newer SDK materials?)
I'm afraid the source code to dtdesc might be lost now.
The Rear Window blog
Belxjander
@Chris...
Yes NDK_3.1/Examples/DataTypes/Bin on the OS Developer 2.1 CD...
@Trixie
Well if it can be updated/replaced it would certainly provide a good basis for DataTypes Descriptor editing
I've dug up a copy I had on a developer CD and work with that for now...
I've had very little result from anything else.
dtdesc is GUI only, it cannot be run from makefiles, therefore it is of no use for serious developers.
Belxjander
@ThomasRapp
well... I haven't found a makefile based solution I am happy with so I am stuck with the gui-only tool for preparing descriptors.
