Amiupdate: login in AmigaOSUpdateServer ?
When starting Amiupdate, it asks for an username and password for "AmigaOSUpdateServer". How can I create those...?
Re: Amiupdate: login in AmigaOSUpdateServer ?
You use the same login details that you use on the Hyperion website .
If you have not created an account there the Hyperion website allows you to create one.
http://www.hyperion-entertainment.biz/
Spectre660 wrote:You use the same login details that you use on the Hyperion website .
Thanks! It works... :-) And I noticed AmiUpdate creates automatically a file named 'SiteList' where the keywords are read from now on.
smf
Post by smf »
Remember to register your products to recieve updates.
