X5000 problems
daveyw
X5000 problems
Post by daveyw »
So it's now been 2 weeks since I first booted up my X5000. Nothing absolutely fatal so far, but here's a few problems I'm seeing:
I can't run ArtEffect. I either get a crash on ramlib, and/or one of the plug-ins as it initialises. On my A1XE the later *sometimes* happens, but this can be avoided by running Art Effect shortly after boot-up.
Speaking of ramlib, I have so far created four partitions on my SSD. Ramlib has crashed everytime upon trying to format the partition. I am using the Format from the Enhancer pack.
Three times I have booted up and found the mouse has gone wonky. It won't move left or right, only up and down, and inverted (so moving the mouse forward moves the pointer down and vice-versa). Additionally, the screen is dragged with it. Only seen it three times so I haven't played around with using a different mouse. Have to reboot.
I have noticed that the Created On stamps on my partitions don't show the actual create date, they show the last boot. They're NGFS.
When I transfer files from my A1XE, I noticed that sometimes the Execute flag switches off. I was seeing these when I transferred via Samba, so thouight it was a network problem, but I have seen it also with files transferred from DVD, so I think it may also be connected with NGFS.
kas1e
Re: X5000 problems
Post by kas1e »
@davew
Dave, try plz default format, if it works and didn't crash then i can make a BZ for aeon's format command, but if it will be the same crash and with default os4's format command, then i can make a BZ for os4 component.
daveyw
Re: X5000 problems
Post by daveyw »
What do you know, I can't replicate it. :oops:
Created two new partitions, formatted one with the stock Format and the other with the Enhancer Format. No problems.
smf
Re: X5000 problems
Post by smf »
what version of arteffect are you trying to run?
Ribdevil
Re: X5000 problems
Post by Ribdevil »
For me, Art Effect 4.0 works fine in my X5000
Virginio
daveyw
Re: X5000 problems
Post by daveyw »
smf wrote:what version of arteffect are you trying to run?
Version 4.0. I tried both a fresh install from CD and just copying across my A1XE files, and both crash. Will post a crash log when I get home tonight.
Ribdevil wrote:For me, Art Effect 4.0 works fine in my X5000
How did you install it? Was there anything special you added or installed? I can't remember when I installed it on my A1XE if anything else needed to be done. I have a vague memory of an updated storm library???
daveyw
Re: X5000 problems
Post by daveyw »
I remembered that I needed to install wizard library from OS4 depot.
Installed it, but still getting a crash on start-up.
Crash log for task "ArtEffect"
Generated by GrimReaper 53.19
Crash occured in module kernel at address 0x01860BC4
Alert number: 0x80000003
Register dump:
   0: 00004364 6BDA5422 25050750 6B4715D0 022D8670 6FFBC000 6B4715D0 6B471610
   8: 696A5CE4 000010D9 00084199 00000000 FFFFFFFA 6964ACE2 00000000 00000001
  16: 6FFA8000 6B4715D4 00000000 20300000 52057050 696A5CE4 6B4715F0 00000000
  24: 00000000 01860BB8 00000664 FFD50001 6FFAC000 00000004 02147340 00000000
   0:              nan    -1.34004e-232     1.64396e-233       4.5036e+15
   4:                0              0.5              nan      2.14748e+09
   8:            65536      1.67772e+07            1e+61            1e-59
  12:                0       4.5036e+15       8.6644e+09     2.30087e-114
  16:     4.42316e-258     -1.93577e+38     -8.18867e+38    -4.77981e-256
  20:              nan      0.000795549       1.1119e+25      9.12293e-68
  24:      3.70538e+72     1.49659e-269      1.95314e+61     2.25329e-183
  28:      4.38455e+41    -5.79178e-183     -1.44659e-17      4.9545e-181
FPSCR (Floating Point Status and Control Register): 0x82024000
           Machine State (msr) : 0x0002F030
                Condition (cr) : 0x69467DB0
      Instruction Pointer (ip) : 0x01860BC4
       Xtended Exception (xer) : 0x01824734
                   Count (ctr) : 0x00000000
                     Link (lr) : 0x00000000
            DSI Status (dsisr) : 0x018439E8
            Data Address (dar) : 0x00000000
680x0 emulated registers:
DATA: 00000004 00000002 00000002 00000000 FFFFFFFF FFD50001 FFD60001 6974A004
ADDR: 651BD484 6964ACE2 6960923A 651BD484 69697004 6BDA5440 69608674 6BDA5416
FPU0:                0                0                0                0
FPU4:                0                0                0                0
Symbol info:
Instruction pointer 0x01860BC4 belongs to module "kernel" (HUNK/Kickstart)
Stack trace:
    native kernel module kernel+0x00060bc4
68k Stack trace:
    696a5ce2 (68k IP) - "ArtEffect" Hunk 000c Offset 0000ace2 (SegList: 1a5d2801)
    69722702 - "ArtEffect" Hunk 0003 Offset 00002702 (SegList: 1a5d2801)
    651bd484 - "ArtEffect" Hunk 000f Offset 00000484 (SegList: 1a5d2801)
    02145450 - "kernel" Hunk 0001 Offset 00015450
    6a92ebf4 - "ArtEffect" Hunk 000d Offset 00000bf4 (SegList: 1a5d2801)
    697227ce - "ArtEffect" Hunk 0003 Offset 000027ce (SegList: 1a5d2801)
    6974a986 - "ArtEffect" Hunk 0000 Offset 00000986 (SegList: 1a5d2801)
    02146bd9 - "kernel" Hunk 0001 Offset 00016bd9
    0193fb54 - "dos.library.kmod" Hunk 0000 Offset 00043ed4
    01936358 - "dos.library.kmod" Hunk 0000 Offset 0003a6d8
    02380000 - "graphics.library.kmod" Hunk 0001 Offset 00004b00
    018fe804 - "dos.library.kmod" Hunk 0000 Offset 00002b84
    65485e10 - "ArtEffect" Hunk 000e Offset 00002e10 (SegList: 1a5d2801)
    6974ae04 - "ArtEffect" Hunk 0000 Offset 00000e04 (SegList: 1a5d2801)
    6974b512 - "ArtEffect" Hunk 0000 Offset 00001512 (SegList: 1a5d2801)
    6974a004 - "ArtEffect" Hunk 0000 Offset 00000004 (SegList: 1a5d2801)
    0185d7bc - "kernel" Hunk 0000 Offset 0005d7bc
68k disassembly:
 696a5cda: 00142648             ori.b             #0x48,(a4)
 696a5cde: 5280                 addq.l            #0x1,d0
 696a5ce0: 6002                 bra.b             0x696a5ce4
*696a5ce2: 10d9                 move.b            (a1)+,(a0)+
 696a5ce4: 5380                 subq.l            #0x1,d0
System information:
CPU
 Model: Freescale P50XX (E5500 core) V1.2
 CPU speed: 1995 MHz
 FSB speed: 798 MHz
 Extensions:
Machine
 Machine name: AmigaOne X5000/20
 Memory: 2097152 KB
 Extensions: bus.pci bus.pcie
Expansion buses
 PCI/AGP
  00:00.0 Vendor 0x1957 Device 0x0421
  01:00.0 Vendor 0x1002 Device 0x6819
   Range 0: 80000000 - 90000000 (PREF.MEM)
   Range 2: 90000000 - 90040000 (MEM)
   Range 4: 00001000 - 00001100 (IO)
  01:00.1 Vendor 0x1002 Device 0xAAB0
   Range 0: 90040000 - 90044000 (MEM)
  02:00.0 Vendor 0x1957 Device 0x0421
  03:00.0 Vendor 0x111D Device 0x8092
  04:01.0 Vendor 0x111D Device 0x8092
  04:02.0 Vendor 0x111D Device 0x8092
  04:03.0 Vendor 0x111D Device 0x8092
  04:08.0 Vendor 0x111D Device 0x8092
  04:10.0 Vendor 0x111D Device 0x8092
  05:00.0 Vendor 0x12D8 Device 0xE111
  06:04.0 Vendor 0x1095 Device 0x3112
   Range 0: 00001000 - 00001008 (IO)
   Range 1: 00001008 - 00001010 (IO)
   Range 2: 00001010 - 00001018 (IO)
   Range 3: 00001018 - 00001020 (IO)
   Range 4: 00001020 - 00001030 (IO)
  06:05.0 Vendor 0x10EC Device 0x8169
   Range 0: 00001100 - 00001200 (IO)
   Range 1: C0000000 - C0000100 (MEM)
  07:00.0 Vendor 0x1B21 Device 0x1080
  08:00.0 Vendor 0x13F6 Device 0x0111
   Range 0: 00002000 - FFFF2100 (IO)
  08:00.1 Vendor 0x13F6 Device 0x0211
   Range 0: 00002100 - FFFF2140 (IO)
Libraries
 0x6bf289d8: english-british.language V52.1
 0x022d7cb2: exec.library V53.89
 0x6ff11a98: cgxvideo.library V42.1
 0x6575ee80: palette.gadget V53.6
 0x64b4a0c4: ae_palette.library V1.0 (Legacy)
 0x64b4a024: ae_angle.library V1.0 (Legacy)
 0x6b7cde14: ae_curve.library V1.0 (Legacy)
 0x66b4ceb4: ae_toolbutton.library V1.0 (Legacy)
 0x66b4cf54: ae_pluginpreview.library V3.0 (Legacy)
 0x68c03dee: ae_display.library V3.0 (Legacy)
 0x6575ec58: ae_vmem.library V3.0 (Legacy)
 0x6b1b9260: mathieeedoubtrans.library V52.2
 0x65605448: wizard.library V51.3
 0x6575dbc8: Separator.docky V53.2
 0x68d455e8: infowindow.class V53.7
 0x66b4b030: texteditor.gadget V53.24
 0x6bd0c880: select.gadget V53.4
 0x669f9e88: sliderbar.gadget V53.17
 0x68c02998: tickbox.gadget V53.6
 0x66a6ec18: filesave.audio V6.5
 0x68c039b8: Mixer.docky V52.5
 0x68c03c50: datesheet.gadget V1.9
 0x68fd8b70: gradientslider.gadget V53.6
 0x68fd8990: getfile.gadget V53.12
 0x68fd88f4: colorwheel.gadget V53.7
 0x6c1a5800: shared.image V2.1
 0x68fd8850: slider.gadget V53.15
 0x66353918: progressbar.gadget V53.10
 0x68fd87b0: getfont.gadget V53.9
 0x66a6ecf8: clicktab.gadget V53.44
 0x68fd83f0: arexx.class V53.5
 0x66004190: requester.class V53.18
 0x68fda288: chooser.gadget V53.21
 0x68fd8350: penmap.image V53.5
 0x68fd82b0: integer.gadget V53.12
 0x6c1a5d04: device.audio V6.2
 0x69034024: clipview.library V1.10
 0x66ab73e0: checkbox.gadget V53.9
 0x6f9219b0: space.gadget V53.6
 0x6bd0f828: screenblanker.library V53.6
 0x6f921f50: bitmap.image V53.9
 0x6ac3eb84: asl.library V53.49
 0x6b562e58: cmi8738.audio V5.18
 0x6b10f378: listbrowser.gadget V53.62
 0x6ff17c50: string.gadget V53.20
 0x6f9217d0: scroller.gadget V53.14
 0x6b4695d4: usergroup.library V4.30
 0x6b472490: bsdsocket.library V4.307
 0x6b562120: mathieeedoubbas.library V52.1
 0x6b80baf8: usbhidgate.library V53.3
 0x6bc0a22c: textclip.library V53.1
 0x6f9ae57c: hid.usbfd V53.12
 0x6bf1ce00: button.gadget V53.21
 0x6bf1cea0: glyph.image V53.3
 0x6bbc5e10: window.class V54.7
 0x6ba24d88: popupmenu.class V53.2
 0x6bbca098: popupmenu.library V53.11
 0x6bf1cd60: label.image V53.13
 0x6bf1ccc0: drawlist.image V53.3
 0x6ff11c78: layout.gadget V54.2
 0x6ba24c90: bevel.image V53.6
 0x6bf1cb80: png.datatype V53.10
 0x6bf5bc64: picture.datatype V53.7
 0x6c32de5c: ft2.library V53.2
 0x6bf21880: Picasso96API.library V54.18
 0x6ff1dc4c: workbench.library V53.53
 0x6bbc5290: gadtools.library V53.7
 0x6bf6f288: timezone.library V53.8
 0x6bf1b128: application.library V53.12
 0x6bf1d3bc: commodities.library V53.7
 0x6c1de540: datatypes.library V54.6
 0x6c32db64: png.iconmodule V53.1
 0x6c18e8cc: icon.library V53.16
 0x6ff14a00: z.library V53.5
 0x6cc347c8: version.library V53.15
 0x6c3305e0: iffparse.library V53.1
 0x6ffb95cc: locale.library V54.2
 0x6ff1841c: diskfont.library V53.9
 0x6f9ae6e8: petunia.library V53.6
 0x6febb220: dos.library V53.158
 0x6ff14364: usbprivate.library V53.14
 0x6ff154bc: massstorage.usbfd V53.83
 0x6ff1421c: hub.usbfd V53.10
 0x6ff15428: bootkeyboard.usbfd V52.3
 0x6ff153a8: bootmouse.usbfd V53.3
 0x6ff152a8: mounter.library V53.19
 0x6ff11e7c: usbresource.library V53.14
 0x6ff9e478: hunk.library V53.4
 0x6ff11d74: elf.library V53.27
 0x6ff6a4d0: intuition.library V54.26
 0x6ff87530: keymap.library V53.9
 0x6ff612c4: nonvolatile.library V54.2
 0x6ff47400: cybergraphics.library V43.0
 0x6ff9d4a0: RadeonHD.chip V2.21
 0x6ffa3420: graphics.library V54.226
 0x6ff9f320: layers.library V54.12
 0x6ff58150: rtg.library V54.90
 0x6ff9d324: PCIGraphics.card V53.15
 0x6ffaa258: newlib.library V53.36
 0x6ff9c1ac: utility.library V54.1
 0x6ffa8398: expansion.library V53.1
 0x6b89658e: rexxsyslib.library V53.4 (Legacy)
Devices
 0x657b7d04: clipboard.device V53.3
 0x6b1418c4: ahi.device V6.6
 0x6b46a608: rtl8169.device V53.5
 0x6f918094: diskimage.device V53.4
 0x6ff9cd10: usbsys.device V53.14
 0x6fe5d024: p5020sata.device V54.69
 0x6ff9eaf0: ehci.usbhcd V53.24
 0x6ff9ea50: ohci.usbhcd V53.21
 0x6ff9e9b0: uhci.usbhcd V53.13
 0x6ff9c848: console.device V53.99
 0x6ff613f0: ramdrive.device V52.6
 0x6ff8777c: input.device V53.5
 0x6ff18024: keyboard.device V53.12
 0x6ff61050: timer.device V53.2
Tasks
 rhd_gc (Waiting)
  Stack: 0x6fec6000 - 0x6fece000, pointer @ 0x6fecdf70 (Cookie OK)
  Signals: SigRec 0x80000001, SigWait 0x00000000
  State: Task (Waiting)
 ClickToFront (Waiting)
  Stack: 0x678b1004 - 0x678c0ffc, pointer @ 0x678c09f0 (Cookie OK)
  Signals: SigRec 0xe000d000, SigWait 0x00000100
  State: Process (Waiting)
 input.device (Waiting)
  Stack: 0x6fea6000 - 0x6feb6000, pointer @ 0x6feb5f00 (Cookie OK)
 AutoPoint (Waiting)
  Stack: 0x66a73004 - 0x66a82ffc, pointer @ 0x66a82a10 (Cookie OK)
 ArtEffect Dispatcher (Waiting)
  Stack: 0x655ba000 - 0x655bc000, pointer @ 0x655bbf50 (Cookie OK)
 USB stack (Waiting)
  Stack: 0x6fec2000 - 0x6fec6000, pointer @ 0x6fec5f20 (Cookie OK)
 EHCI Controller Task Unit 0 (Waiting)
  Stack: 0x6fa19000 - 0x6fa21000, pointer @ 0x6fa20f10 (Cookie OK)
  Signals: SigRec 0xbe009000, SigWait 0x00000000
 EHCI Controller Task Unit 1 (Waiting)
  Stack: 0x6f9d9000 - 0x6f9e1000, pointer @ 0x6f9e0f10 (Cookie OK)
 p5020sata.device Port 0 (Waiting)
  Stack: 0x6fe4e000 - 0x6fe5ca60, pointer @ 0x6fe5c8d0 (Cookie OK)
  Signals: SigRec 0xd000f000, SigWait 0x08000000
 p5020sata.device Port 1 (Waiting)
  Stack: 0x6fc32000 - 0x6fc40a60, pointer @ 0x6fc408d0 (Cookie OK)
 SDH1/NGFileSystem 54.34  (Waiting)
  Stack: 0x6ef87004 - 0x6ef8effc, pointer @ 0x6ef8ed60 (Cookie OK)
  Signals: SigRec 0xf0000000, SigWait 0x00000100
 SDH4/NGFileSystem 54.34  (Waiting)
  Stack: 0x6d50f004 - 0x6d516ffc, pointer @ 0x6d516d60 (Cookie OK)
 DH0/NGFileSystem 54.34  (Waiting)
  Stack: 0x6f878004 - 0x6f87fffc, pointer @ 0x6f87fd60 (Cookie OK)
 SDH3/NGFileSystem 54.34  (Waiting)
  Stack: 0x6dde0004 - 0x6dde7ffc, pointer @ 0x6dde7d60 (Cookie OK)
 SDH2/NGFileSystem 54.34  (Waiting)
  Stack: 0x6e6a5004 - 0x6e6acffc, pointer @ 0x6e6acd60 (Cookie OK)
 SDH5/NGFileSystem 54.34  (Waiting)
  Stack: 0x6cc4a004 - 0x6cc51ffc, pointer @ 0x6cc51d60 (Cookie OK)
 hid.usbfd (Waiting)
  Stack: 0x6b75e004 - 0x6b765ffc, pointer @ 0x6b765e90 (Cookie OK)
  Signals: SigRec 0xe0000000, SigWait 0x00000100
 HID Mouse (Waiting)
  Stack: 0x6b630004 - 0x6b63fffc, pointer @ 0x6b63ff20 (Cookie OK)
 reaper.task (Waiting)
  Stack: 0x6c2f1004 - 0x6c2f8ffc, pointer @ 0x6c2f8e50 (Cookie OK)
 ICD1/CDFileSystem 53.4  (Waiting)
  Stack: 0x6b614004 - 0x6b623ffc, pointer @ 0x6b623f30 (Cookie OK)
 ICD0/CDFileSystem 53.4  (Waiting)
  Stack: 0x6b6af004 - 0x6b6beffc, pointer @ 0x6b6bef30 (Cookie OK)
 RAM/ram-handler 53.172  (Waiting)
  Stack: 0x6c209004 - 0x6c20cffc, pointer @ 0x6c20cd40 (Cookie OK)
 hid.usbfd (Waiting)
  Stack: 0x6f8fd004 - 0x6f904ffc, pointer @ 0x6f904e90 (Cookie OK)
 HID Keyboard (Waiting)
  Stack: 0x6b4b8004 - 0x6b4c7ffc, pointer @ 0x6b4c7f10 (Cookie OK)
  Signals: SigRec 0x90001000, SigWait 0x00000000
 HID Consumer (Waiting)
  Stack: 0x6b4a4004 - 0x6b4b3ffc, pointer @ 0x6b4b3f20 (Cookie OK)
 hid.usbfd (Waiting)
  Stack: 0x6b76a004 - 0x6b771ffc, pointer @ 0x6b771e90 (Cookie OK)
 ArtEffect VMem Server (Waiting)
  Stack: 0x69584004 - 0x69594004, pointer @ 0x69593f50 (Cookie OK)
  Signals: SigRec 0xc0000001, SigWait 0x00000100
 rtl8169.device.0 (Waiting)
  Stack: 0x6aad3004 - 0x6abc7ffc, pointer @ 0x6abc7ef0 (Cookie OK)
  Signals: SigRec 0x78008000, SigWait 0x00000100
 URL/launch-handler 53.38  (Waiting)
  Stack: 0x6b4cc004 - 0x6b546ffc, pointer @ 0x6b542fb0 (Cookie OK)
 RANDOM/Random-Handler 52.1  (Waiting)
  Stack: 0x6b588004 - 0x6b597ffc, pointer @ 0x6b597ef0 (Cookie OK)
 dos_filedir_notify (Waiting)
  Stack: 0x6f8bd004 - 0x6f8c0ffc, pointer @ 0x6f8c0ad0 (Cookie OK)
  Signals: SigRec 0x40001000, SigWait 0x80000000
 CON/con-handler 53.78  (Waiting)
  Stack: 0x666e4004 - 0x666f3ffc, pointer @ 0x666f3e20 (Cookie OK)
  Signals: SigRec 0xa0000100, SigWait 0x00000000
 AllKeys (Waiting)
  Stack: 0x65fe5004 - 0x65ff4ffc, pointer @ 0x65ff4820 (Cookie OK)
  Signals: SigRec 0xf0001000, SigWait 0x00000100
  Stack: 0x69361004 - 0x69370ffc, pointer @ 0x69370e20 (Cookie OK)
  Stack: 0x65fc9004 - 0x65fd8ffc, pointer @ 0x65fd8e20 (Cookie OK)
  Stack: 0x66b18004 - 0x66b27ffc, pointer @ 0x66b27e20 (Cookie OK)
  Stack: 0x66694004 - 0x666a3ffc, pointer @ 0x666a3e20 (Cookie OK)
  Stack: 0x66a27004 - 0x66a36ffc, pointer @ 0x66a36e20 (Cookie OK)
  Stack: 0x66ea2004 - 0x66eb1ffc, pointer @ 0x66eb1e20 (Cookie OK)
  Stack: 0x671f9004 - 0x67208ffc, pointer @ 0x67208e20 (Cookie OK)
  Stack: 0x676c1004 - 0x676d0ffc, pointer @ 0x676d0e20 (Cookie OK)
  Stack: 0x678cd004 - 0x678dcffc, pointer @ 0x678dce20 (Cookie OK)
  Stack: 0x6bc4d004 - 0x6bc5cffc, pointer @ 0x6bc5ce20 (Cookie OK)
  Stack: 0x6bca1004 - 0x6bcb0ffc, pointer @ 0x6bcb0e20 (Cookie OK)
 AUDIO/AHI-Handler 6.2  (Waiting)
  Stack: 0x6b70b004 - 0x6b71b004, pointer @ 0x6b71aed0 (Cookie OK)
 ENV/env-handler 54.5  (Waiting)
  Stack: 0x6c2e9004 - 0x6c2ecffc, pointer @ 0x6c2ecef0 (Cookie OK)
 APPDIR/appdir-handler-in-dos 53.158  (Waiting)
  Stack: 0x6c295004 - 0x6c29cffc, pointer @ 0x6c29cdc0 (Cookie OK)
  Stack: 0x6c325004 - 0x6c32cffc, pointer @ 0x6c32ce20 (Cookie OK)
 RAW/con-handler 53.78  (Waiting)
  Stack: 0x6c33d004 - 0x6c344ffc, pointer @ 0x6c344e20 (Cookie OK)
  Stack: 0x6c369004 - 0x6c370ffc, pointer @ 0x6c370e20 (Cookie OK)
 dos_nbmd_process (Waiting)
  Stack: 0x6f8cd004 - 0x6f8d0ffc, pointer @ 0x6f8d0f30 (Cookie OK)
 dos_lock_handler (Waiting)
  Stack: 0x6f8d5004 - 0x6f8d8ffc, pointer @ 0x6f8d8f00 (Cookie OK)
 RexxMaster (Waiting)
  Stack: 0x6b416004 - 0x6b426004, pointer @ 0x6b425f70 (Cookie OK)
  Stack: 0x6b5e5004 - 0x6b5f8ffc, pointer @ 0x6b5f8c50 (Cookie OK)
  Stack: 0x6b680004 - 0x6b693ffc, pointer @ 0x6b693c50 (Cookie OK)
 TEXTCLIP/textclip-handler 53.1  (Waiting)
  Stack: 0x6b56c004 - 0x6b57bffc, pointer @ 0x6b57beb0 (Cookie OK)
 compose.task (Waiting)
  Stack: 0x697e3000 - 0x697eb000, pointer @ 0x697eaf30 (Cookie OK)
  Signals: SigRec 0x00000021, SigWait 0x00000000
 Workbench (Waiting)
  Stack: 0x6b117004 - 0x6b126ffc, pointer @ 0x6b126ea0 (Cookie OK)
 ScreenBlanker Library. (Waiting)
  Stack: 0x69041004 - 0x69051ffc, pointer @ 0x69051f00 (Cookie OK)
  Signals: SigRec 0xb4001000, SigWait 0x00000100
 ramlib (Waiting)
  Stack: 0x6c23b004 - 0x6c253ffc, pointer @ 0x6c253f20 (Cookie OK)
  Stack: 0x6abd3004 - 0x6abe2ffc, pointer @ 0x6abe2f40 (Cookie OK)
 ContextMenus Command Dispatcher (Waiting)
  Stack: 0x65203004 - 0x65212ffc, pointer @ 0x65212f30 (Cookie OK)
 texteditor.gadget Clipboard Server (Waiting)
  Stack: 0x6560b004 - 0x65623ffc, pointer @ 0x65623f00 (Cookie OK)
 New Process (Waiting)
  Stack: 0x68db3004 - 0x68dc2ffc, pointer @ 0x68dc2f40 (Cookie OK)
  Stack: 0x6bd7d004 - 0x6bd8cffc, pointer @ 0x6bd8cdb0 (Cookie OK)
  Stack: 0x6ac77004 - 0x6ac86ffc, pointer @ 0x6ac86f00 (Cookie OK)
 NotificationServer (Waiting)
  Stack: 0x6721d004 - 0x6723cffc, pointer @ 0x6723c2e0 (Cookie OK)
  Signals: SigRec 0xbc001000, SigWait 0x00000000
 AmiDock (Waiting)
  Stack: 0x6bcd1004 - 0x6bce0ffc, pointer @ 0x6bce0920 (Cookie OK)
 ELF Collector (Waiting)
  Stack: 0x6f853004 - 0x6f862ffc, pointer @ 0x6f862e70 (Cookie OK)
 TCP/IP Control (Waiting)
  Stack: 0x6acc5004 - 0x6adb9ffc, pointer @ 0x6adb9dc0 (Cookie OK)
  Signals: SigRec 0xf8009080, SigWait 0x00000100
 Calendar (Waiting)
  Stack: 0x66ebe004 - 0x66ecdffc, pointer @ 0x66ecd830 (Cookie OK)
  Signals: SigRec 0x6e001000, SigWait 0x00000000
 hub.usbfd (Waiting)
  Stack: 0x6f999004 - 0x6f9a0ffc, pointer @ 0x6f9a0f10 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6f9a5004 - 0x6f9acffc, pointer @ 0x6f9acf10 (Cookie OK)
 Background CLI [FilerCX] (Waiting)
  Stack: 0x66341004 - 0x66350ffc, pointer @ 0x66350cb0 (Cookie OK)
  Signals: SigRec 0x40001000, SigWait 0x00000100
 Background CLI [wait] (Waiting)
  Stack: 0x68e48004 - 0x68e57ffc, pointer @ 0x68e57f00 (Cookie OK)
 TimeGuard (Waiting)
  Stack: 0x66ae4004 - 0x66af3ffc, pointer @ 0x66af3e00 (Cookie OK)
  Signals: SigRec 0xf0001000, SigWait 0x0ff40100
 Background CLI [SYS:Samba/bin/nmbd] (Waiting)
  Stack: 0x64f7e004 - 0x64f8dffc, pointer @ 0x64f8d450 (Cookie OK)
  Signals: SigRec 0x00001080, SigWait 0x00000100
 Mounter GUI (Waiting)
  Stack: 0x6b820004 - 0x6b833ffc, pointer @ 0x6b833e10 (Cookie OK)
  Signals: SigRec 0x80007000, SigWait 0x00000000
 ScreenBlankerEngine (Waiting)
  Stack: 0x678e9004 - 0x678f8ffc, pointer @ 0x678f8bf0 (Cookie OK)
  Signals: SigRec 0xd8001000, SigWait 0x00000100
 TCP/IP Superserver (Waiting)
  Stack: 0x6adbe004 - 0x6aeb2ffc, pointer @ 0x6aeb29f0 (Cookie OK)
  Signals: SigRec 0xd0000080, SigWait 0x00000000
  Stack: 0x6aeb7004 - 0x6afabffc, pointer @ 0x6afabe10 (Cookie OK)
  Signals: SigRec 0xf8003000, SigWait 0x00000100
 clipview.library server (Waiting)
  Stack: 0x6566b004 - 0x6568affc, pointer @ 0x6568ae00 (Cookie OK)
  Signals: SigRec 0xd8003000, SigWait 0x00000000
 Mixer (Waiting)
  Stack: 0x6937d004 - 0x6938cffc, pointer @ 0x6938cc80 (Cookie OK)
  Signals: SigRec 0x78011000, SigWait 0x00000100
 ContextMenus (Waiting)
  Stack: 0x676d5004 - 0x676e4ffc, pointer @ 0x676e4c90 (Cookie OK)
  Signals: SigRec 0xe0001000, SigWait 0x00000100
 select.gadget prefs (Waiting)
  Stack: 0x65839004 - 0x65848ffc, pointer @ 0x65848c90 (Cookie OK)
 AutoInfo (Waiting)
  Stack: 0x666c0004 - 0x666cfffc, pointer @ 0x666cfcb0 (Cookie OK)
  Signals: SigRec 0xc0001000, SigWait 0x00000000
 AsyncWB (Waiting)
  Stack: 0x6bcb5004 - 0x6bcc4ffc, pointer @ 0x6bcc4eb0 (Cookie OK)
  Signals: SigRec 0xc0001000, SigWait 0x00000100
 « IPrefs » (Waiting)
  Stack: 0x6bc28004 - 0x6bc37ffc, pointer @ 0x6bc37960 (Cookie OK)
  Signals: SigRec 0x0000f000, SigWait 0x20000100
 AutoBorderSize (Waiting)
  Stack: 0x66a4b004 - 0x66a5affc, pointer @ 0x66a5acb0 (Cookie OK)
  Stack: 0x6bc07000 - 0x6bc07fa0, pointer @ 0x6bc07f10 (Cookie OK)
 RAWBInfo (Waiting)
  Stack: 0x6bc71004 - 0x6bc80ffc, pointer @ 0x6bc80ec0 (Cookie OK)
 DefIcons (Waiting)
  Stack: 0x6bc85004 - 0x6bc94ffc, pointer @ 0x6bc94dc0 (Cookie OK)
 TCP/IP Log (Waiting)
  Stack: 0x6afb0004 - 0x6b0a4ffc, pointer @ 0x6b0a4f00 (Cookie OK)
 ConClip (Waiting)
  Stack: 0x6b477004 - 0x6b486ffc, pointer @ 0x6b486eb0 (Cookie OK)
 USB stack Process (Waiting)
  Stack: 0x6b838004 - 0x6b847ffc, pointer @ 0x6b847ee0 (Cookie OK)
 MassStorage Notifier (Waiting)
  Stack: 0x6fe65000 - 0x6fe6cd00, pointer @ 0x6fe6cc70 (Cookie OK)
 datatypes.library (Waiting)
  Stack: 0x6ba79004 - 0x6ba88ffc, pointer @ 0x6ba88e30 (Cookie OK)
 DST watcher (Waiting)
  Stack: 0x6bbd6004 - 0x6bbe5ffc, pointer @ 0x6bbe5f10 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6f959004 - 0x6f960ffc, pointer @ 0x6f960f10 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6f94d004 - 0x6f954ffc, pointer @ 0x6f954f10 (Cookie OK)
 ArtEffect (Crashed)
  Stack: 0x6bd9e004 - 0x6bda5534, pointer @ 0x6bda5422 (Cookie OK)
  Signals: SigRec 0x00000020, SigWait 0x40000100
  State: Process (Crashed)
 ramlib.support (Waiting)
  Stack: 0x6c258004 - 0x6c270ffc, pointer @ 0x6c270f00 (Cookie OK)
  Signals: SigRec 0x80005000, SigWait 0x00000000
 Mounter Task (Waiting)
  Stack: 0x6fe6d000 - 0x6fe7ba60, pointer @ 0x6fe7b970 (Cookie OK)
  Signals: SigRec 0xb0001000, SigWait 0x00000000
 Mounter Companion Process (Waiting)
  Stack: 0x6b864004 - 0x6b873ffc, pointer @ 0x6b873f40 (Cookie OK)
 dos_signal_server (Waiting)
  Stack: 0x6f8c5004 - 0x6f8c8ffc, pointer @ 0x6f8c8f10 (Cookie OK)
  Signals: SigRec 0x0000f000, SigWait 0x00000000
 dos_appdir_server (Waiting)
  Stack: 0x6f8b1004 - 0x6f8b8ffc, pointer @ 0x6f8b8d40 (Cookie OK)
 idle.task (Ready)
  Stack: 0x6ff86000 - 0x6ff87000, pointer @ 0x6ff86fc0 (Cookie OK)
  State: Task (Ready)
Ribdevil
Re: X5000 problems
Post by Ribdevil »
I have installed in my 1200 with OS 3.9.
Only copy the drawer and make an assign to this.
And yes, I have wizard.library installed
amigasociety
Re: X5000 problems
Post by amigasociety »
daveyw wrote: Three times I have booted up and found the mouse has gone wonky. It won't move left or right, only up and down, and inverted (so moving the mouse forward moves the pointer down and vice-versa). Additionally, the screen is dragged with it. Only seen it three times so I haven't played around with using a different mouse. Have to reboot.
Wireless mouse or usb cabled?
I experience this sometimes too, mouse cursor gets stuck upper top left on screen. If I move the mouse it barely moves but not in right direction and only left and right. I blame it on my wireless logitech mouse maybe conflicting with a 2nd exact same mouse I use on my linux box.
I notice if I turn that linux computer off during boot (or at least the mouse on it) it does not happen, as often, but I do get it if I leave that mouse powered on during boot of the X5K.
It is weird for sure. Wonder if the logitech wireless tech that allows the one USB dongle to accept many devices gets confused.
Wonder if some kind of wireless usb mouse conflict?
Or has nothing to do with it but I do get kinda what you get.
TJ
AmigaOne X5000
Amiga A1222 Tabor
daveyw
Re: X5000 problems
Post by daveyw »
amigasociety wrote: Wireless mouse or usb cabled?
It's a basic wired mouse Zalman ZM-M201R
amigasociety wrote:TJ
Please tell me you're TJ Miller from Silicon Valley/Deadpool. :D
