Play FLAC songs with Datatypes
mritter0
Post by mritter0 »
I am adding support to play FLAC song files in my project. I use this code to play MP3s, but it will not play FLACs
if ((SoundObject=IDataTypes->NewDTObject(SoundPath,
	DTA_GroupID,						GID_SOUND,
TAG_END)))
	PreviewSoundSignal=IExec->AllocSignal(-1);
	IDataTypes->SetDTAttrs(SoundObject,MainWindow,NULL,
		SDTA_SignalTask,					IExec->FindTask(NULL),
		SDTA_SignalBitMask,					1L << PreviewSoundSignal,
	TAG_DONE);
	IDataTypes->DoDTMethod(SoundObject,NULL,NULL,DTM_TRIGGER,NULL,STM_PLAY,NULL);
	SoundPlaying=TRUE;
It fails at the NewDTObject() function. The FLACs are being identified as 'Sound' (why aren't MP3s and FLACs considered 'Music'?). I also tried GID_MUSIC, same result.
MultiViewer will play the FLACs.
Any ideas?
Re: Play FLAC songs with Datatypes
mritter0 wrote: MultiViewer will play the FLACs.
Any ideas?
Easy one first, GID_MUSIC refers to a score, tab or other representation of the music, perhaps midi, though in reality midi datatypes are usually GID_SOUND. There isn't a base class for GID_MUSIC at the current time. If there wwere it would likely *display* the score so a musician could read and play it.
IN terms of why music files are soundf iles, there is no meaningful difference between the sound of a rock being banged repeatedly in rhythm and the sound of a landslide, except in the human brain. :-)
Here's my sound player from AOrganiser. Note that I set the src type explicitly and a few other settigs.
I don't have any FLACS to test with or a FLAC datatype installed for that matter.
        case ALARM_SOUND:
        	if(al->al_Data.al_Sound.al_SoundFile)
        		/* skip alarm if we are playing one! */
        		/* at the moment we are single process so thos should be all we need */
				/* if we add multi tasking then a semaphore might be required */
        		if(!diary->dd_CurrentSound)
        			diary->dd_CurrentSound  = IDataTypes->NewDTObject(al->al_Data.al_Sound.al_SoundFile,
        						DTA_SourceType,DTST_FILE,
        						SDTA_Volume,64,
        						SDTA_Cycles,1,
        						SDTA_SignalBitNumber,SIGBREAKB_CTRL_F,
        					TAG_DONE);
	        		if(diary->dd_CurrentSound)
        				struct dtTrigger dtt = {0};
        				dtt.MethodID = DTM_TRIGGER;
        				dtt.dtt_GInfo = NULL;
        				dtt.dtt_Function = STM_PLAY;
        				dtt.dtt_Data = NULL;
        				IIntuition->IDoMethodA(diary->dd_CurrentSound,(Msg)&dtt);
        	break;
My main loop waits for the signal.
				                            if(sig & SIGBREAKF_CTRL_F)
				                            	/* the sound we were playing stopped */
				                            		IDataTypes->DisposeDTObject(diary->dd_CurrentSound);
				                            		diary->dd_CurrentSound = NULL;
mritter0
Post by mritter0 »
I got up in the middle of the night. Added in DTA_SourceType,DTST_FILE, it works now. Must need that little extra kick.
