Amiga One (sam460ex)
mjnurney
Post by mjnurney »
hello all,
im sorry if this has been asked before but I'm stumped...
My A500 (Sam 460ex) (radeon RV730) is refusing to give out any sound after a reinstall of Workbench...AHI says music unit0 is muted but how do i change this? ...it did work before.
Also does the Sam output sound via HDMI ? i cannot remember if i had this running via VGA and Audio 3.5 cable... its been a while...
Amiga One 500
OS 4.1 FE
thanks
mike. :evil:
Scrub that..
Audio working via rear audio jack. Fronts are not connected at all (AC97) however should the Sam have audio via HDMI as well ?
javierdlr
Re: Amiga One (sam460ex)
Post by javierdlr »
mjnurney wrote:hello all,
Scrub that..
AFAIK, there is no hdmi_audio driver yet, so no audio output from HDMI.
So you must stick to use internal SM502 audio or a PCI/PCIe sound card.
mjnurney
Post by mjnurney »
thanks ...
that saves me playing with the settings for for hours..
