Mesa & DRI for PPC
caseycullen
Mesa & DRI for PPC
Post by caseycullen »
I was able to build Mesa 17.2.0-devel with DRI 3 support on X5000 using xeno's instructions: http://forum.hyperion-entertainment.biz ... &start=100
glxgears values are improved :)
Re: Mesa & DRI for PPC
caseycullen wrote:I was able to build Mesa 17.2.0-devel with DRI 3 support on X5000 using xeno's instructions: http://forum.hyperion-entertainment.biz ... &start=100
Hi Caseycullen,
Many thanks for testing the new Mesa 17.2.0-devel with DRI 3 support on your X5000. Your Glxgears values have been really improved. Well done! :-)
I released the RC4 of Mesa 18.0.0 for testing today.
Download: mesa-18.0.0-rc4-linux-powerpc.tar.gz
Installation instructions:
  1. Code: Select all
    sudo cp -R mesa-18.0.0-rc4 /usr/local/
  2. Code: Select all
    sudo mv /usr/lib/powerpc-linux-gnu/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/r600_dri.so.bak
  3. Code: Select all
    sudo mv /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0.bak
  4. Code: Select all
    sudo cp /usr/local/mesa-18.0.0-rc4/lib/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/
  5. Code: Select all
    sudo cp /usr/local/mesa-18.0.0-rc4/lib/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/
I successfully tested it with the MATE PowerPC Remix (X1000) and with ubuntu MATE 16.04.3 LTS PowerPC (X5000) today.
The MATE PowerPC Remix 2017 with the RC4 of Mesa 18.0.0 on an AmigaOne X1000 with a Radeon HD6870:
ubuntu MATE 16.04.3 LTS PowerPC with the RC4 of Mesa 18.0.0 on an AmigaOne X5000 with a Radeon HD4870:
caseycullen
Christian,
Thanks for the Mesa 18.0 download! I have tested it on MATE PowerPC Remix with kernel 4.15.0-RC7 and with no issues. I'll test with newer kernel shortly.
---Casey
caseycullen
Tested Mesa 18.0 with kernel 4.16-rc2; no issues noticed.
---Casey
caseycullen wrote:Tested Mesa 18.0 with kernel 4.16-rc2; no issues noticed.
---Casey
Hi Casey,
Many thanks for testing and thanks a lot for the screenshots!
X5000 with R 250 Radeon (no hardware support) running MESA 18
Skateman wrote:X5000 with R 250 Radeon (no hardware support) running MESA 18
Thanks a lot for testing Mesa 18!
I compiled the final version of Mesa 18.0.0 today.
Build instructions:
./configure --prefix /usr/local/mesa-18.0.0 --with-gallium-drivers="r600,swrast" --enable-texture-float --enable-dri3
Output:
        prefix:          /usr/local/mesa-18.0.0
        exec_prefix:     ${prefix}
        libdir:          ${exec_prefix}/lib
        includedir:      ${prefix}/include
        OpenGL:          yes (ES1: yes ES2: yes)
        OSMesa:          no
        DRI platform:    drm
        DRI drivers:     r200 radeon swrast
        DRI driver dir:  ${libdir}/dri
        GLX:             DRI-based
        EGL:             yes
        EGL drivers:     builtin:egl_dri2 builtin:egl_dri3
        GBM:             yes
        EGL/Vulkan/VL platforms:   x11 surfaceless drm
        Vulkan drivers:  no
        llvm:            no
        Gallium drivers: r600 swrast
        Gallium st:      mesa
        HUD extra stats: no
        HUD lmsensors:   no
        Shared libs:     yes
        Static libs:     no
        Shared-glapi:    yes
        CFLAGS:          -g -O2 -Wall -Werror=implicit-function-declaration -Werror=missing-prototypes -Wmissing-prototypes -fno-math-errno -fno-trapping-math -std=c99
        CXXFLAGS:        -g -O2 -Wall -fno-math-errno -fno-trapping-math
        CXX11_CXXFLAGS:  -std=c++11
        LDFLAGS:
        Macros:          -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -D_GNU_SOURCE -DUSE_GCC_ATOMIC_BUILTINS -DMISSING_64BIT_ATOMICS -DNDEBUG -DTEXTURE_FLOAT_ENABLED -DHAVE_XLOCALE_H -DHAVE_SYS_SYSCTL_H -DHAVE_STRTOF -DHAVE_MKOSTEMP -DHAVE_TIMESPEC_GET -DHAVE_STRTOD_L -DHAVE_DL_ITERATE_PHDR -DHAVE_POSIX_MEMALIGN -DHAVE_ZLIB -DHAVE_LINUX_FUTEX_H -DHAVE_LIBDRM -DGLX_USE_DRM -DGLX_INDIRECT_RENDERING -DGLX_DIRECT_RENDERING -DGLX_USE_TLS -DHAVE_X11_PLATFORM -DHAVE_SURFACELESS_PLATFORM -DHAVE_DRM_PLATFORM -DHAVE_DRI3 -DENABLE_SHADER_CACHE -DHAVE_MINCORE
        PYTHON2:         python2.7
        Run 'make' to build Mesa
make
# make install
or
sudo make install
export LD_LIBRARY_PATH=/usr/local/mesa-18.0.0/lib/
glxinfo | grep -i opengl
LIBGL_DEBUG=verbose vblank_mode=0 glxgears
Download: mesa-18.0.0-linux-powerpc.tar.gz
  1. Code: Select all
    sudo cp -R mesa-18.0.0 /usr/local/
  2. Code: Select all
  3. Code: Select all
  4. Code: Select all
    sudo cp /usr/local/mesa-18.0.0/lib/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/
  5. Code: Select all
    sudo cp /usr/local/mesa-18.0.0/lib/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/
Screenshot:
Is it worth (or even possible) upgrading if not using a r600 based GPU? (As i am using a Radeon R7 250)
