Installation Utility ARCHIVEPACKAGE and other questions
I'm putting togther an Installer using the python based Installtion Utility.
Part of the installation downloads archives of dependencies from os4depot and I'd like to simply install one of those with a package of type ARCHIVEPACKAGE
However code like this
def installProAction():
	installedpath = GetEnv("Appdir/Proaction")
	archive = fetchArchive("http://os4depot.net/share/library/reaction/proaction.lha")
	if archive:
		myArchives = [archive]
		print myArchives
		if installedpath:
			if os.path.basename(installedpath).upper() == "PROACTION":
				installedpath = os.path.dirname(path)
			proactionpkg = AddPackage(ARCHIVEPACKAGE,
				name="ProAction Package",
				alternatepath = installedpath,
				description="",
				files = myArchives
		else:
				description="",
				files = myArchives
	else:
		os.system("C:RequestChoice \"Download Failed\" \"Unable to download the ProAction archive\" \"OK\"")
emits an error like this:
Installing ProAction!
['proaction.lha']
Exception exceptions.OSError: 'Cannot create package of requested type' in 'garbage collection' ignored
Also I couldn't create a page of type PACKAGESELECT, the SDK installer uses such IIRC although it appears to be an all binary installer so maybe it's not based Installation Utility despite it's similar look and feel.
Re: Installation Utility ARCHIVEPACKAGE and other questions
@broadblues
I don't know anything about Python but I did look at the SDK installer and "Installation Utility" with the Dopus4 HEX reader and the SDK Installer contains text referring to XAD (xadmaster.library). On the other hand, even though "Installation Utility" contains the term ARCHIVEPACKAGE there is no text referring to XAD, xadmaster.library or lha. In addition, all the archives (lha) on the OS4.1FE installation CD seem to be handled by AmigaDOS scripts or "Installer" scripts. It seems likely that "Installation Utility" may not actually handle archives like the SDK installer.
Is OS4Depot reliable enough to have your program rely on it for dependencies?
