Sysbench
Sam460ex 1155 Mhz
Debian/Stretch/Sid
sysbench --num-threads=1 --test=cpu --cpu-max-prime=20000 --validate run
sysbench 0.4.12: multi-threaded system evaluation benchmark
Running the test with following options:
Number of threads: 1
Additional request validation enabled.
Doing CPU performance benchmark
Threads started!
Done.
Maximum prime number checked in CPU test: 20000
Test execution summary:
total time: 350.9746s
total number of events: 10000
total time taken by event execution: 350.9676
per-request statistics:
min: 34.95ms
avg: 35.10ms
max: 282.54ms
approx. 95 percentile: 35.13ms
Threads fairness:
events (avg/stddev): 10000.0000/0.00
execution time (avg/stddev): 350.9676/0.00
sysbench --num-threads=2 --test=cpu --cpu-max-prime=20000 --validate run
Number of threads: 2
Threads started!
Done.
total time: 351.2607s
total time taken by event execution: 702.5068
min: 64.02ms
avg: 70.25ms
max: 148.96ms
approx. 95 percentile: 72.01ms
Threads fairness:
events (avg/stddev): 5000.0000/0.00
execution time (avg/stddev): 351.2534/0.00
sysbench --num-threads=4 --test=cpu --cpu-max-prime=20000 --validate run
Number of threads: 4
Threads started!
Done.
total time: 352.3206s
total time taken by event execution: 1409.2094
min: 132.58ms
avg: 140.92ms
max: 354.79ms
approx. 95 percentile: 143.96ms
Threads fairness:
events (avg/stddev): 2500.0000/0.00
execution time (avg/stddev): 352.3024/0.01
Benchmark Results
Re: Benchmark Results
HARDINFO
Benchmarks
Benchmarks
CPU Blowfish
CPU Blowfish (Lower is Better)
e5500 2x 1995.00 MHz 17.357
460EX Rev. B 1x 1155.00 MHz 57.296
CPU CryptoHash
CPU CryptoHash (Higher is Better)
e5500 2x 1995.00 MHz 105.599
460EX Rev. B 1x 1155.00 MHz 24.449
CPU Fibonacci
CPU Fibonacci (Lower is Better)
e5500 2x 1995.00 MHz 2.992
460EX Rev. B 1x 1155.00 MHz 4.373
CPU N-Queens
CPU N-Queens (Lower is Better)
e5500 2x 1995.00 MHz 11.306
460EX Rev. B 1x 1155.00 MHz 14.454
CPU Zlib
CPU Zlib (Higher is Better)
e5500 2x 1995.00 MHz 0.163
460EX Rev. B 1x 1155.00 MHz 0.026
FPU FFT
FPU FFT (Lower is Better)
e5500 2x 1995.00 MHz 14.052
460EX Rev. B 1x 1155.00 MHz 52.880
FPU Raytracing
FPU Raytracing (Lower is Better)
e5500 2x 1995.00 MHz 12.421
460EX Rev. B 1x 1155.00 MHz 40.220
GPU Drawing
GPU Drawing (Higher is Better)
e5500 2x 1995.00 MHz 827.095
460EX Rev. B 1x 1155.00 MHz 144.923
Benchmarks
Benchmarks
CPU Blowfish
CPU CryptoHash
CPU Fibonacci
CPU N-Queens
CPU Zlib
FPU FFT
FPU Raytracing
GPU Drawing
