Library seglist pointer type
trixie
Post by trixie »
Looking at various library and BOOPSI class sources, I keep seeing the library base seglist member declared as either APTR or BPTR. I also see that depending on that declaration, the respective libClose and libExpunge vectors return either APTR or BPTR. Which of the two pointer types is correct?
The Rear Window blog
Re: Library seglist pointer type
Post by thomasrapp »
Does not matter as long as you return the same 32 bits as you received in your library init function.
On 68k it's surely a BPTR as returned by LoadSeg().
trixie
Post by trixie »
@thomasrapp
That's what I thought would be the case (and what I've been using for years myself). I was just surprised to see APTRs here and there in library sources, and also <exec/libraries.h> in the latest OS4 SDK has a structure in which the seglist is declared as an APTR. So I've been wondering whether this is an inconsistency or whether the type doesn't matter.
@trixie
A seglist is a BPTR but it hardly matters if all you are going to do is store and return it at expunge time. uint32 would be sufficicent for that.
If you want to do anything else with it, then it should be considered an anonymous handle and only manipulated with dos functions such as GetSegListInfo() in which case the segment argument is a BPTR .
I suppose exec includes might refer to it as APTR to remove the dependency on dos related include files?
trixie
Post by trixie »
broadblues wrote:@trixie
Could be. Perhaps the Exec developers could shed some light on this?
