Anyone have AmiDVD 1.51 and X5000 successfully burn .ISO?
Mine acts strange.
LG DVD/CD unit as installed by Amiga on The Lake
Launch AmiDVD and I get some immediate errors in a window.
SCSI command 46 00 00 00 00 00 00 10 00 00 failed
sense: 70 00 05 00 00 00 00 0a 00 00 00 00 20 00 00 00 00 00
SCSI command 5a 00 2a 00 00 00 00 00 64 00 failed
After that the AmiDVD app opens but in Tab 3 it does not see my DVD unit so I can't select it to burn the .ISO too.
If I insert a already written to CD it then populates with the p5020sata.device but that won't do my any good as I want to insert a blank CD or DVD so I can burn the .ISO to it.
It is as if AmiDVD can't see blank media. I tried two different brand CDRW and one DVDr. Neither will get AmiDVD to popup thep5020sata.device in Tab 3.
So with AmiDVD launched I remove the readable media that had data on it and when done, the console window starts reporting error after error and will not stop, I insert a blank media, no change. I close the error window and it immediatley reappears showing errors, so I quit AmiDVD.
I then try to relaunch AmiDVD and get a new error window "could not open device" and AmiDVD will not longer launch.
Anyone else have these issues?
Appears AmiDVD as per installed from Amiga OS 4.1FE for X5K has issues.
I may try downloading the older 2008 version from OS4Depot to see what happens.
TJ
AmiDVD 1.51 & X5000 to burn .ISO
- amigasociety
AmigaOne X5000
Amiga A1222 Tabor
AmigaOne X5000
Amiga A1222 Tabor
Re: AmiDVD 1.51 & X5000 to burn .ISO
SCSI Error Codes
Your first error is that it can't read the configuraton (46) - go figure
Your second error is MODE SENSE(10) - whatever that means
I still use 1.49 and the only thing i got in tooltypes is "DRIVE=CD0", maybe worth a try.
Do you have a chance to try another dvd drive, might be the hardware?
Burning a CD/DVD needs a driver with working ATAPI command set, p5020sata.device is not finished yet, so you will probably run into problems.amigasociety wrote:Anyone have AmiDVD 1.51 and X5000 successfully burn .ISO?
Mine acts strange.
If you really need to burn CD/DVD's you might have success adding a SII3112 card and attaching your DVD drive to that for now.
OS4.1 for the X5000 is still in beta remember.
Hope this helps
Darren
- amigasociety
Hope this helps
Darren
I just burned from my loonix box instead but now that I know it is the driver, I will wait until future to try again on X5K.
TJ
AmigaOne X5000
Amiga A1222 Tabor
AmigaOne X5000
Amiga A1222 Tabor
I am using the OS4Depot version on my A1XE and also have SCSI error window open whenever I launch the program.amigasociety wrote:
TJ
SCSI command 00 00 00 00 00 00 failed
sense: 71 00 02 00 00 00 00 0a 00 00 00 00 3a 01 00 00 00 00
It's done that ever since I switched from pata to sata.
But it still works - just burnt an ubuntu x86 iso that I used to install on a Win7 laptop.
