Hi Guys
So i have a copy of AmigaOS4.1 FE, Went to register it yesterday on the Hyperion Website, there is no option for OS4.1 FE MicroA1.
- So, what should I select? The Amigaone XE/SE option?
Cheers
Mikey C
Registering OS4.1 FE U1. With MicroA1... Question
Re: Registering OS4.1 FE U1. With MicroA1... Question
Hi Mikey,
I think it's unimportant just what platform you have - since it's an identical set of OS components for the XE/SE and µA1, I'd go with the XE/SE choice.
Mikey_C wrote:Hi Guys
Cheers
Mikey C
Yes , select AmigeOne XE/SE option .
