I have noticed the clock runs extremely fast. Is this x50000 issue or AmigaOS issue?
Doug
Time accuracy
Re: Time accuracy
Runs perfectly OK for everyone else. I would suggest that you have an issue with your clock hardware, but I'd check the 3V battery first.
Probably the easiest fix is to add to the S:Network-Startup, the line "C:Date Server <time URL> Port 123". That will set the time automatically every time you boot the machine.
Re: Time accuracy
Thanks for suggestion, I really only noticed it due to not rebooting as I was away for a week and it gained about 30 minutes.
Hopefully not defective hardware.
Doug
Doug
