I just upgraded my AOS4.1FE on my PPC A1200.
the installation went smoothly well
also the reboot.
but now if I try to start odyssey, the amiga resets
same with OWB
If I start netsurfer, the amiga freezes
I had also other freeezes with other programs.
what's that?
any idea?
well, I can reinstall AOS4.1FE again, I have the cd, but shouldn't an upgrade be for the better?
regards
4.1 FE Update 1 problems on A1200ppc
Satiropan
PPA1200 (Poor Portable Amiga 1200): BPPC-160MB,
BVision-CGX4, HD 10GB, slim DVD R/W, Asus VW161D
display, 3COM Lan PC card, OS4.1FE
AmigaOne G3-SE 600MHz, 1GB, Radeon 9200 128DDR,
CS4281 sound card, RTL8029, SiI3114, OS 4.1.6 & OS4.1FE
http://www.oldfab.webs.com
- DarrenHD
Re: 4.1 FE Update 1 problems on A1200ppc
Strange. Can you confirm everything is working fine on AmigaOS 3.9 side? (PPC etc...?) Since you were able to make it through the installation that tells me the PPC is likely OK. 4.1 does stress the PPC more than it would under OS 3.9 as the 68k on the Blizzard is totally disabled and the PPC is used 100% of the time. Is your ram set to 70ns ?satiropan wrote:I just upgraded my AOS4.1FE on my PPC A1200.
also the reboot.
same with OWB
what's that?
any idea?
regards
I don't have a 3.9 side, and the ram is setted as 70ns
before the upgrade it was working ok, although slow
I think the a1200ppc 175mhz has reached its limit
I am thinking of dismantling and selling everything
you know, I am now old, 67, I no longer want to waste time and money to get this machine working, I use amiga since 1988, now I am tired
Satiropan
I can confirm the same problem update 1 here. Lot of applications just crash with frozen mouse, rarely with reset. usually demanding applications like Netsurf and Odyssey. At first I thought that I should lower the speed of memory from 60 ns to 70ns but that didnt help. Then I dissasembled my Amiga 1200 tower and reinserted/cleaned contacts.
I tested with MiniGL demos to see if problems will arise with system 100% busy but it survived 3 hours without problems. The crashes occurs in a dynamic use, not the static high CPU load. Then I tried to turn off commodities from WBStartup Preferences (AsyncWB, DefIcons; RAWBinfo, ScreenBlankerEngine, ClickToFront, ContextMenus, AmiDock, RinghioServer).
Most of the system freeze also led to improper internal BlizzardPPC clock (date was OK, but time was not correct any more). I tried to use battclock.resource.kmon from the ordinary FE release in combination with update 1 also.
Now I am back to regular FE release and the system is stable. I have a dual boot set up (normal FE, FE update1) so I can test further.
I have to check also without new MUI release because that is also upgraded.
What can I do to test some more? Some debug mode to test more?
My hardware configuration is:
A1200
BlizzardPPC 603e 200 MHz, 66 MHz FSB, 256 MB RAM EDO
BVisionPPC
- Dooz
A1200
BVisionPPC
- Dooz
I tested new MUI with regular AOS 4.1 FE and no problems appear. System is stable. I will try now with FE Update 1 and old MUI installation.
Somehow I suspect that operating system crash with MUI programs. I will test new combination.
If that doesnt help I will install clean FE with update 1 and test.
-Dooz
-Dooz
I reinstalled the aos4.1fe and then the upgrade one, problems seem gone
Satiropan
no, sorry, but problems still are there, I cannot start odyssey, nor owb, the system will reset. I tried erasing a cdrw disc, with amidvd, it will freeze. I think I will go back to standard aos4.1fe
Satiropan
Ive had similar issues after upgrading but always make a complete system backup before doing it. so it was easy to revert back. I hope a patch will come.
Amiga 1200 Kickstart 3.1 (40.68), Elbox Power/Winner tower, BlizzardPPC 603e+ @240mhz & 060 @50mhz, 256MB 60ns, BlizzardvisionPPC, IDE-fix Express, IndivisionAGA, 120GB IDE, cd, dvd, Cocolino, Micronik Keycase, PCMCIA Ethernet
Just thought I'd elaborate a little bit. I've done some testing with a fresh install of OS4.1 Final. With that set up, I seem to have no issues running the more demanding applications like Dosbox, OWB and Timberwolf (rc1. rc3 wont run for some reason).
After applying Update 1 it's a whole different story. Aforementioned apps do not work at all. For example, Timberwolf (I was quite focussed getting it to work again) always crashes when loading. When this happens the OS4.1 logo appears (trough my indivsion) but its a lot dimmer than usual, for some reason. There is repetitive hard drive activity, but nothing is loading. OS4.1 never comes on. In such cases, I have to do another reboot to get back to OS4.1.
Since everything was finally running okay for me without Update 1, I went back to a clean install of 4.1 Final and am not going to bother with Update 1 until someone knows how to deal with the issues mentioned.
I do, ofcourse, appreciate the work that's gone into it.
Rotzloeffel
Same Problem here on A1200 since the last known MUI-Update I am unable to start Odyssey... System crashes after opening the window or screen..... Problem exists since mid of April....satiropan wrote:no, sorry, but problems still are there, I cannot start odyssey, nor owb, the system will reset. I tried erasing a cdrw disc, with amidvd, it will freeze. I think I will go back to standard aos4.1fe
BTW... Odyssey is no longer downloading the required fonts! There are issues with the certificates..... AmiSSL 4.x is installed....
