radeon - failed to load r600
caseycullen
Post by caseycullen »
Sorry if I missed an explanation of this posted already, I've not found a reference to this issue and it has been puzzling me. My video seems to be functioning correctly, except I keep seeing an error:
casey@Utopia:~$ glxgears
libGL error: Version 7 or imageFromFds image extension not found
libGL error: failed to load driver: r600
I believe hardware acceleration is working:
casey@Utopia:~$ glxinfo | grep OpenGL
OpenGL vendor string: X.Org
OpenGL renderer string: Gallium 0.4 on AMD BARTS (DRM 2.48.0)
OpenGL core profile version string: 3.2 (Core Profile) Mesa 11.2.0
OpenGL core profile shading language version string: 1.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.0 Mesa 11.2.0
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 11.2.0
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
Running glxgears seems to give good values:
casey@Utopia:~$ vblank_mode=0 glxgears
ATTENTION: default value of option vblank_mode overridden by environment.
7133 frames in 5.0 seconds = 1426.516 FPS
7097 frames in 5.0 seconds = 1419.041 FPS
7247 frames in 5.0 seconds = 1449.393 FPS
7412 frames in 5.0 seconds = 1482.110 FPS
7343 frames in 5.0 seconds = 1468.531 FPS
7359 frames in 5.0 seconds = 1471.635 FPS
7190 frames in 5.0 seconds = 1437.919 FPS
7338 frames in 5.0 seconds = 1467.579 FPS
Any idea what the "libGL error / failed to load r600" messages are about?
Radeon HD 6870 on Ubuntu-Mate 16.04 with kernel 4.10-rc4
Re: radeon - failed to load r600
Hi Caseycullen,
I have the same graphics card and the same Mesa version but I don't have this issue on ubuntu MATE 16.04 LTS.
ubuntu MATE 16.04 LTS with kernel 4.10-rc6 and with a Radeon HD 6870 on my AmigaOne X1000.
christian@ubuntu:~$ glxinfo | grep OpenGL
OpenGL extensions:
christian@ubuntu:~$ vblank_mode=0 glxgears
6930 frames in 5.0 seconds = 1385.840 FPS
7821 frames in 5.0 seconds = 1564.019 FPS
7822 frames in 5.0 seconds = 1564.330 FPS
7793 frames in 5.0 seconds = 1558.476 FPS
7717 frames in 5.0 seconds = 1543.393 FPS
7837 frames in 5.0 seconds = 1567.214 FPS
7840 frames in 5.0 seconds = 1567.880 FPS
7843 frames in 5.0 seconds = 1568.556 FPS
7842 frames in 5.0 seconds = 1568.276 FPS
7842 frames in 5.0 seconds = 1568.262 FPS
7849 frames in 5.0 seconds = 1569.624 FPS
7839 frames in 5.0 seconds = 1567.734 FPS
7313 frames in 5.0 seconds = 1462.465 FPS
7805 frames in 5.0 seconds = 1560.948 FPS
7781 frames in 5.0 seconds = 1556.119 FPS
Maybe a package is missing. A new Mesa version is available for ubuntu MATE 16.04.1 LTS. Please upgrade your system. Maybe it solves the issue.
I successfully upgraded ubuntu MATE 16.04.1 LTS today and I got the Mesa version 12.0.6.
OpenGL renderer string: Gallium 0.4 on AMD BARTS (DRM 2.48.0 / 4.10.0-rc6_A-EON_AmigaONE_X1000_Nemo)
OpenGL core profile version string: 3.2 (Core Profile) Mesa 12.0.6
OpenGL version string: 3.0 Mesa 12.0.6
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 12.0.6
@Casecullen
Please upgrade your ubuntu MATE 16.04.1 LTS.
caseycullen
xeno74 wrote:@Casecullen
Hi Christian,
Thanks for your response. I updated ubuntu-Mate to Mesa 12.0.6 and still received the message. To be sure install was OK I did fresh install of ubuntu-Mate 16.04 and upgraded packages again to Mesa 12.0.6; and also tried with kernel 4.10.0-rc5. Unfortunately I still see this message:
OpenGL renderer string: Gallium 0.4 on AMD BARTS (DRM 2.48.0 / 4.10.0-rc5-X5000-Sinan)
OpenGL extensions:
I saw in X1000 forum musa was getting the same error; but it looked like it was fixed by upgrading to Mesa 13.
Hi Casecullen,
Yes, maybe Mesa 13 fixes the issue but why I don't have this issue?
Could you please post more details of your Radeon HD6870?
mechanic
Post by mechanic »
lib/modules ?
caseycullen
xeno74 wrote: Could you please post more details of your Radeon HD6870?
Hi Christian / mechanic,
Thanks for your reply! I have a Sapphire Radeon HD 6870, I believe it has reference card specs... This Card
More card info...
root@Utopia:/home/casey# lspci -vnn | grep VGA -A 12
0000:01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Barts XT [Radeon HD 6870] [1002:6738] (prog-if 00 [VGA controller])
	Subsystem: PC Partner Limited / Sapphire Technology Barts XT [Radeon HD 6870] [174b:e177]
	Flags: bus master, fast devsel, latency 0, IRQ 27
	Memory at c00000000 (64-bit, prefetchable) [size=256M]
	Memory at c10000000 (64-bit, non-prefetchable) [size=128K]
	I/O ports at 1000 [size=256]
	Expansion ROM at c10040000 [disabled] [size=128K]
	Capabilities: [50] Power Management version 3
	Capabilities: [58] Express Legacy Endpoint, MSI 00
	Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
	Capabilities: [150] Advanced Error Reporting
	Kernel driver in use: radeon
lsmod
root@Utopia:/home/casey# lsmod
Module                  Size  Used by
uio_pdrv_genirq         7397  0
uio                    17418  1 uio_pdrv_genirq
Also I noticed this error, I'm not sure what this module is or if it could be related?
root@Utopia:/home/casey# systemctl status systemd-modules-load.service
● systemd-modules-load.service - Load Kernel Modules
   Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2017-02-02 22:12:58 CST; 2 days ago
     Docs: man:systemd-modules-load.service(8)
           man:modules-load.d(5)
  Process: 2051 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 2051 (code=exited, status=1/FAILURE)
root@Utopia:/home/casey# journalctl _PID=2051
-- Logs begin at Thu 2017-02-02 22:12:58 CST, end at Sat 2017-02-04 20:50:31 CST. --
Feb 02 22:12:58 Utopia systemd-modules-load[2051]: Failed to find module 'lp'
Feb 02 22:12:58 Utopia systemd-modules-load[2051]: Failed to find module 'ppdev'
Feb 02 22:12:58 Utopia systemd-modules-load[2051]: Failed to find module 'parport_pc'
Do you have the package "linux-firmware" installed? I installed it but it made no difference.
---Casey
tlosmx
Post by tlosmx »
plz can you share a shot of the wrong colors?
i think compiz is using opengles 1 or opengles 2 this library heve endianess in colors on linux.
your speed in glxgears suffer by version of xorg + version of mesa. old mate version means slowest performances
this are my performances on glxgears on mate 16.10 X.Org X Server 1.18.4 and mesa 17 rc2 on a 6570HD
8812 frames in 5.0 seconds = 1762.292 FPS
9624 frames in 5.0 seconds = 1924.756 FPS
9725 frames in 5.0 seconds = 1944.889 FPS
10203 frames in 5.0 seconds = 2040.538 FPS
10180 frames in 5.0 seconds = 2035.892 FPS
9948 frames in 5.0 seconds = 1989.544 FPS
caseycullen
tlosmx wrote:plz can you share a shot of the wrong colors?
Hi tiosmx,
My colors are fine on 16.04.1 with Mesa 12.0.6.
The error prevents some software from running, like VLC:
casey@Utopia:~$ vlc
VLC media player 2.2.2 Weatherwax (revision 2.2.2-0-g6259d80)
[102f2918] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Illegal instruction (core dumped)
I only get wrong colors on 17.04 using compiz.
What version of Mesa do you have? I think the upstream version is only up to 13...
tlosmx
Post by tlosmx »
Hi im using Mesa 17.0 rc2 ,
but im pretty sure the wrong color are because the last version of compiz who is present on mate 17.04 probably is using gles or gles2.
this why i was asking a screenshot ... because wrong color can be from mesa gles bug or altivec optimizations .
Im using Mate 16.10 on X5000, i hope christian will made an img for 17.04 for check what wrong there and help better
Vlc crash because altivec instruction i know this for sure.
Usually i rebuild some system libs without altivec like SDL and SDL2 or FFMpeg etc
