I've installed a frontal hub (Digitus DA-70133-2 - VPR3.0). The manufacturer says what this support USB 1.1 and 2.0.
I've plugged into J19A connector and this works,
but with this new AmigaOS 4.1.3 release I've changed to J17 connector (port #5)... however now the hub don't work 8'^(.
I've plugged an USB key and the system don't recognize it (and all leds from the hub continues off). Hints?
Regards
[SAM440ep-Flex] J17 port - SOLVED!!
Re: [SAM440ep-Flex] J17 port
I observed the same thing with J17. I had disconnected my internal multicard reader a few weeks ago and tried to plug it in on Sunday but nothing worked with J17. The cable is not long enough to connect to J19A so I did not try that at the time. I am now also running Update 3 .
AmiSpaTra wrote:I've installed a frontal hub (Digitus DA-70133-2 - VPR3.0). The manufacturer says what this support USB 1.1 and 2.0.
Regards
Still not working
Guess that we should read the Manual .
System:Documentation/usb/usb_ohci_readme
The OHCI driver supports following UBoot variables:
usb_enable_4x0 - if set to "on" or "1", the ohci interface
of the PPC 440ep or PPC 460ex cpus are activated.
You said...
, thanks.
You are my hero. SOLVEDSpectre660 wrote:Guess that we should read the Manual .
