Backup your Linux partition
You can create an img from the Linux partition with dd directly.
For example:
dd if=/dev/sdb1 of=~/ubuntu_MATE_17.04.img
(from another booted Linux system)
If your partition is too big then it is possible to create an img with dd in the size of your used part of the partition and format it. After that mount it and rsync the files to this mounted img.
  1. Boot your Linux system for example ubuntu MATE 17.04
  2. Code: Select all
    dd if=/dev/zero of=ubuntu_MATE_17.04.img count=20000 bs=1M
    (20G image)
  3. Code: Select all
    mkfs.ext4 ubuntu_MATE_17.04.img
  4. Code: Select all
    tune2fs -c0 -i0 ubuntu_MATE_17.04.img
  5. Code: Select all
    sudo mount ubuntu_MATE_17.04.img /mnt/
  6. Code: Select all
    sudo rsync --stats --progress --numeric-ids -axAhHSP  / /mnt/ --exclude=/dev --exclude=/proc --exclude=/sys --exclude=/tmp --exclude=/mnt --exclude=/media
  7. Code: Select all
    sudo mkdir /mnt/tmp /mnt/sys /mnt/proc /mnt/dev /mnt/media
Good luck!
