Graphical glitch in NeoGUI (GnGeo emulator)
samo79
Post by samo79 »
Since the installation of the FE Update 1 there is now a visible graphical glitch into the NeoGUI window :-/ ... probably a compositing issue ?
Test it: http://os4depot.net/index.php?function= ... /gngeo.lha
Re: Graphical glitch in NeoGUI (GnGeo emulator)
And what is wrong? Can you describe the fault, or give us a screenshot without the fault?
I don't know how it is meant to look.
What platform are you running on?
samo79
Post by samo79 »
tonyw wrote:And what is wrong? Can you describe the fault, or give us a screenshot without the fault?
Well it should be like this --> http://os4depot.net/filedata/snapshot/5904_1_snap.jpg
My machine is a Sam440ep Flex 800 + Radeon 9250 and AmigaOS 4.1 Final Edition Update 1
No problem instead with the old Final Edition
Without knowing how the image is rendered it hard to say, but in the first instance you should contact the author and get him to check there is no error in the GUI code that has been revealed by the update to a more recent component.
I can confirm it happens on my SAM with latest beta.
samo79
Post by samo79 »
broadblues wrote:Without knowing how the image is rendered it hard to say, but in the first instance you should contact the author and get him to check there is no error in the GUI code that has been revealed by the update to a more recent component.
The author is Vicente 'Ami603' Gimeno, he is an OS4 team member i think ...
I've sent him an email...
Ami603
Post by Ami603 »
Hello , i've seen the issue and am currently investigating it.No promises on timeframe,thouh
gh.
Vicente Gimeno
Betatester Number: A1-X1096
Fractal Design Define R3 (without branding and boingball)
GFX Card: Club3D Radeon HD4650, 512Mb DDR2 128Bit, Passive cooling.
PSU: OCZ StealthxStream pro 500W Modular
4Gb RAM
500Gb SATA +160Gb PATA WD Hardisks
Sony SATA DVDRW
4Gb UDMA Hi Speed Compact Flash.
Ami603
Post by Ami603 »
Hi, please test this version and let me know if it solves your problem.
I rewrote the preview rendering code, should be cleaner (safer also) now.
http://ami603.amiga-projects.net/NeoGUI
Vicente Gimeno
4Gb RAM
Sony SATA DVDRW
javierdlr
Post by javierdlr »
Ami603 wrote:Hi, please test this version and let me know if it solves your problem.
Yes, now shows GUI correctly. THX!!!!!
samo79
Post by samo79 »
Yeah, it solve the problem, thank you 8-)
Before you release it i attach you an update for my old italian translation ;)
NeoGUI_italian.lha
(2.59 KiB) Downloaded 1019 times
