When I input and data in my Add URL column it will accept e.g. app name ODYSSEY then when I try to add string in next column the whole line goes blank. I have tied saving after initial entry but still failure can anyone help please.
Add URL wont let me input data
Finally got my x5000 up and running
installed Amistore and tried to login no success I remembered I had to add a string to the sys/prefs/ url and this is where the issue lies.
- javierdlr
Re: Add URL wont let me input data
Tested here on my SAM460ex and no problem, no black string or alike.
Can you post a screen grab to see it more "clear" your problem?
TIA
TIA
I think if I under stand the question... just add the text in the field then TAB to the next field and so on...
Doh! that did the trick
I'm very rusty been away a while
many thanks.
many thanks.
