Kernel 4.9 (Longterm)
Sam460ex 4.9.0 kernel .
(Boot via U-boot shell from USB thumb drive or tftp server)
The ttyS0 argument needs to be removed from the linux command line for the systemd output to be displayed
on the console. example setting for Uboot using AmigaOS 4.1 command nvsetvar :
nvsetvar bootargs="root=/dev/sda6"
New AmigaOS 4.1 uboot script
https://drive.google.com/open?id=0BxoZd ... y1BcF9kYjA
4.9.0 kernel
https://drive.google.com/open?id=0BxoZd ... zh4RmhxTjA
javierdlr
Re: Kernel 4.9
Post by javierdlr »
Spectre660 wrote:Sam460ex 4.9.0 kernel .
In the new script did you miss/forget 'ext2load ${pt} {rl} {ur};' part? (3000000 uRamdisk)
Or isn't needed anymore with such 4.9.0 kernel image?
Re: Kernel 4.9
I took these out as they are for the ramdisk installers so not needed for regular usage.
I have the newer installer scripts in the Documents directory on the new Linux installer USB .img .
http://forum.hyperion-entertainment.biz ... =52&t=3643 .
Re: Kernel 4.9
Sam460ex 4.9.11 kernel .
https://drive.google.com/open?id=0BxoZd ... V9fbWIxVkk
Re: Kernel 4.9
Sam460ex 4.9.13 kernel .
(Boot via U-boot shell from USB thumb drive or tftp server).
https://drive.google.com/open?id=0BxoZd ... 1F0Wm8yREE
Re: Kernel 4.9
Spectre660 wrote:Sam460ex 4.9.13 kernel .
Thank you for the stable longterm kernel 4.9.13 for the Sam460ex. :-)
javierdlr
Re: Kernel 4.9
Post by javierdlr »
Spectre660 wrote:Sam460ex 4.9.11 kernel .
Hi, just tested kernel 4.9.11 on my SAM460ex booting fine (usinf TFTP)
javierdlr@Sam460ex:~$ uname -a
Linux Sam460ex 4.9.11-sam460ex-jm #1 PREEMPT Thu Feb 23 06:41:23 AST 2017 ppc ppc ppc GNU/Linux
sorry for soooo big delay, will test other kernels ASAP
Re: Kernel 4.9
Sam460ex 4.9.17 kernel .
https://drive.google.com/file/d/0BxoZdO ... sp=sharing
Re: Kernel 4.9
Sam460ex 4.9.24 kernel .
https://drive.google.com/open?id=0BxoZd ... Dc0Q0tyS2M
Re: Kernel 4.9 (Longterm)
Sam460ex 4.9.25 kernel .
https://drive.google.com/open?id=0BxoZd ... WozWVpmSWc
