GADGETUP message missing if gadget is in sub layout
- TSK
- Location: Home land of Santa C., sauna, sisu and salmiakki
I've been developing some BOOPSI gadget classes. If I let Intuition to take care of the mouse wheel then an application will get a GADGETUP message but only if the gadget is in a root layout group. If the gadget is in any child/sub group then the GADGETUP message won't appear at all. Is that a bug in Intuition or Layout class or is there any way to make that GMR_VERIFY/GADGETUP to go through all layout levels ? Reaction Slider can handle it somehow.
Keep the party going !
- salass00
Re: GADGETUP message missing if gadget is in sub layout
If there was a bug like you describe then it would be affecting almost all of the ReAction programs in existence since nesting layout gadgets is not uncommon.
For gadgets that are inside a layout (root or nested) the IDCMP_GADGETDOWN / IDCMP_GADGETUP messages are in any case completely useless since they always point to the root layout. This is why layout.gadget uses IDCMP_IDCMPUPDATE messages to provide this information (see LAYOUT_RelVerify and LAYOUT_Immediate tags). If you use window.class and WM_HANDLEINPUT then it automatically takes care of these details for you and returns them as WMHI_GADGETDOWN and WMHI_GADGETUP events respectively.
- TSK
@salass00
So how do I implement it in my class to get this working ? Like I said WMHI_GADGETUP never arrives.
- broadblues
From conversations on this subject held in email I should point out that the significant piece of information missing from this request for help is that it applies to GM_HANDLESCROLL not GM_HANDLEINPUT
Maybe if Tuomas posts some example code that isn't working that might also aid in detecting the problem.
- salass00
You implement GM_HITTEST, GM_GOACTIVE, GM_HANDLEINPUT and GM_GOINACTIVE as usual. The IDCMP_IDCMPUPDATE notification is done by layout.gadget in its input handler. Your gadget gadget should also have GACT_RELVERIFY set (GA_RelVerify) to produce gadget up events.TSK wrote: So how do I implement it in my class to get this working ? Like I said WMHI_GADGETUP never arrives.
- salass00
The GM_HANDLESCROLL method isn't documented in any of the autodocs but it looks like the requirements to produce a gadget up event are the same. GACT_RELVERIFY has to be set on the gadget and the method should return with GMR_VERIFY set.broadblues wrote:From conversations on this subject held in email I should point out that the significant piece of information missing from this request for help is that it applies to GM_HANDLESCROLL not GM_HANDLEINPUT
- TSK
I think you mean GA_RelVerify.GACT_RELVERIFY
The both are done, of course.GMR_VERIFY
Yes, I mentioned mouse wheel in the first post.it applies to GM_HANDLESCROLL
- salass00
Setting GA_RelVerify to TRUE sets the GACT_RELVERIFY flag in the gadget->Activation field, setting GA_RelVerify to FALSE clears it.TSK wrote:I think you mean GA_RelVerify.GACT_RELVERIFY
Have you added some debug code to ensure that your GM_HANDLESCROLL method actually gets called?Yes, I mentioned mouse wheel in the first post.it applies to GM_HANDLESCROLL
Also make sure that IDCMP_GADGETUP messages are enabled on the window.
- TSK
Yes to both. HandleScroll is called. The window is window class window.
- salass00
Try setting LAYOUT_DeferLayout to TRUE on the root layout.
If it helps then I think I know what the problem is and how to fix it.
