Kernel 4.4
Kernel 4.4
Sam460ex 4.4.25 kernel .
(Boot via U-boot shell from USB thumb drive or tftp server)
https://dl.dropboxusercontent.com/u/542 ... .25.tar.gz
USB boot .img
https://dl.dropboxusercontent.com/u/542 ... 4.4.25.img
Re: Kernel 4.4
Sam460ex 4.4.27 kernel .
Removed the realtime clock.
added support for Oland based radeon graphics cards .
https://dl.dropboxusercontent.com/u/542 ... .27.tar.gz
Re: Kernel 4.4
Spectre660 wrote:Sam460ex 4.4.27 kernel .
Thank you. :-)
Re: Kernel 4.4
Sam460ex 4.4.28 kernel .
https://dl.dropboxusercontent.com/u/542 ... -jm.tar.gz
Re: Kernel 4.4
Sam460ex 4.4.29 kernel .
real time clock support reinstated .
To disable UTC and use Local Time in Ubuntu 16.04:
open terminal (Ctrl+Alt+T) and run the command below :
timedatectl set-local-rtc 1 --adjust-system-clock
To check out if your system uses Local time, just run:
timedatectl
you’ll the local time zone is in use in the Warning section
Re: Kernel 4.4
Sam460ex 4.4.30 kernel .
Re: Kernel 4.4
Sam460ex 4.4.35 kernel .
Re: Kernel 4.4
Sam460ex 4.4.38 kernel .
Re: Kernel 4.4
Updated Sam460ex 4.4.38 kernel .
Fixes problem when rebooting from Linux into AmigaOS 4.1 .
https://www.dropbox.com/s/s33q2jzymv8xr ... ar.gz?dl=0
or
https://drive.google.com/open?id=0BxoZd ... VRuWksyUlk
Re: Kernel 4.4
Spectre660 wrote:Updated Sam460ex 4.4.38 kernel .
Thanks a lot! :-)
