Roadshow 1.12
papaoskar
Roadshow 1.12
Post by papaoskar »
I read about a new Roadshow Version 1.12 in Amiga News.
Question, Whether we get a new Roadshow for X1000?
I am asking, because I encountered several Problems when downloading larger files as Attachments to mails receiving with YAM 2.10 dev.
Yam got in an endless circle and could only be stopped by a total hard reset. Same occoured with YAM 2.9p1, but not so often.
Therefore I believe that the tcp stack is the culprit, not YAM.
Any comments?
Re: Roadshow 1.12
papaoskar wrote:I read about a new Roadshow Version 1.12 in Amiga News.
Any comments?
What's the size of the "larger files" that cause problems. I'm still using YAM 2.7 and can test sending myself a file if know how large the problem files are. What settings do you have in YAM Configuration/New mail/Size limit & "Download large messages" ?? There is also a possibility that your mail server can't handle large emails.
papaoskar
Re: Roadshow 1.12
Post by papaoskar »
It seems to me that the file size in larger than about 2-3 MBit. I can't say because it always ends with a hard reset. The size is a guess by me based on time of observing the transmission .
On the other hand I can receive pictures over 3 MB size.
Cheers
Re: Roadshow 1.12
papaoskar wrote: It seems to me that the file size in larger than about 2-3 MBit. I can't say because it always ends with a hard reset. The size is a guess by me based on time of observing the transmission .
Cheers
I just attached a 15MB raw camera file (resulting in a 20MB email) to an email and sent it to my alternate email address. It sent and received fine (slow on send). I doubt if RoadShow is your problem.
salass00
Re: Roadshow 1.12
Post by salass00 »
If you need to be sending files that are in the size class of megabytes you should consider using another method than e-mail attachments as they were not designed for files this size.
papaoskar
Re: Roadshow 1.12
Post by papaoskar »
salass00 wrote:If you need to be sending files that are in the size class of megabytes you should consider using another method than e-mail attachments as they were not designed for files this size.
Well understood. The basic background question was do I need an update for roadshow. I still use the one delivered with "OS 4.1 Final" ?
It was one of first X1000 and it could be that there is an update necessary.
I can receive those big mails with YAM2.9p1 without Problems. It could be that the interaction of YAM2.10 dev with roadshow makes a problems. Who knows?
Re: Roadshow 1.12
There has been only one version of Roadshow for many years, the same version is used on all Amigas. There is nothing unusual about the X-1000 version.
There is an updated version of Roadshow that has just been released a few days ago, but it should behave exactly like the old version. There may be a few new bugs to be ironed out, but it is not likely to change the behaviour of YAM on your X-1000.
If you have problems with your YAM installation, it is more likely to be caused by your setup than by any of the software supplied with Final Edition.
