ubuntu MATE 16.04.1 Live DVD
I figured out that our X1000 boots with the ubuntu MATE 16.04.1 Live DVD.
Unfortunately we need a xorg.conf with a configured fbdev on the Live DVD. Without a xorg.conf, the MATE desktop doesn't start and we can't switch to a shell.
The question was, how can I boot the Live DVD and copy a xorg.conf to /etc/X11?. The text boot argument doesn't work but I solved this problem with the following commands:
  1. Code: Select all
    CFE> ramdisk -addr=0x24000000 -fs=iso atapi0.1:casper/powerpc64/initrd
  2. Code: Select all
    CFE> setenv bootargs "root=/dev/ramdisk boot=casper single“
  3. Code: Select all
    CFE> boot -elf -noints -fatfs cf0:vmlinux-4.7
  4. Press Enter for maintenance
  5. Code: Select all
    mount -o rw,remount /
  6. Code: Select all
    dhclient
  7. Code: Select all
    wget http://www.xenosoft.de/X.org.conf.zip
  8. Code: Select all
    unzip X.org.conf.zip
  9. Code: Select all
    cp xorg.conf.radeon /etc/X11/xorg.conf
  10. Code: Select all
    vi /etc/X11/xorg.conf
    I replaced radeon with fbdev
  11. Code: Select all
    startx
The desktop works from the Live DVD but unfortunately the installer (ubiquity) crashes.
How can I integrate the xorg.conf on the Live DVD?
Re: ubuntu MATE 16.04.1 Live DVD
I tried to boot the Live DVD with the framebuffer driver without copying the xorg.conf.
  1. Code: Select all
  2. Code: Select all
    CFE> setenv bootargs "root=/dev/ramdisk file=/cdrom/preseed/ubuntu-mate.seed boot=casper video=offb:off nomodeset video=radeonfb:1600x1200-32@60"
  3. Code: Select all
I saw the boot messages but unfortunately Xorg doesn't work either.
More success!
I figured out, that we don't need mount -o rw,remount / because the file system is already rw. With init 5 I was able to continue the default start of the Live DVD. The default ubuntu MATE live desktop works now but unfortunately the installer ubiquity crashed.
  1. Code: Select all
  2. Code: Select all
    CFE> setenv bootargs "root=/dev/ramdisk file=/cdrom/preseed/ubuntu-mate.seed boot=casper single"
  3. Code: Select all
  5. Code: Select all
    dhclient
  6. Code: Select all
  7. Code: Select all
  8. Code: Select all
  9. Code: Select all
    init 5
Error message of ubiquity:
ubiquity crashed with IndexError in free_space(): list index out of range.
I was able to install some packages for example hardinfo. On the screenshot you can see the crash log of ubiquity.
I installed ubiquity on my ubuntu MATE 16.04.1 LTS today. Unfortunately the same problem. That means the Live DVD isn't the problem. Ubiquity doesn't work. We didn't recognise that because we copied via "dd" Julian's images to our hard disks. Therefore we didn't need the ubiquity installer.
I was able to integrate the xorg.conf to the Live DVD with the following commands:
  1. Code: Select all
    mkdir /home/christian/livecdtmp
  2. Code: Select all
    mv ubuntu-mate-16.04.1-desktop-powerpc.iso /home/christian/livecdtmp/
  3. Code: Select all
    cd /home/christian/livecdtmp
  4. Code: Select all
    mkdir mnt
  5. Code: Select all
    sudo mount -o loop ubuntu-mate-16.04.1-desktop-powerpc.iso mnt
  6. Code: Select all
    mkdir extract-cd
  7. Code: Select all
    sudo rsync --exclude=/casper/filesystem.squashfs -a mnt/ extract-cd
  8. Code: Select all
    sudo unsquashfs mnt/casper/filesystem.squashfs
  9. Code: Select all
    sudo mv squashfs-root edit
  12. Code: Select all
    sudo cp xorg.conf.radeon edit/etc/X11/xorg.conf
  13. Code: Select all
    sudo vi edit/etc/X11/xorg.conf
  14. I replaced radeon with fbdev
  15. Code: Select all
    sudo mksquashfs edit extract-cd/casper/filesystem.squashfs
  16. Code: Select all
    sudo su
  17. Code: Select all
    printf $(du -sx --block-size=1 edit | cut -f1) > extract-cd/casper/filesystem.size
  18. Code: Select all
    exit
  19. Code: Select all
    cd extract-cd
  20. Code: Select all
    sudo rm md5sum.txt
  21. Code: Select all
    find -type f -print0 | sudo xargs -0 md5sum | grep -v isolinux/boot.cat | sudo tee md5sum.txt
  22. Code: Select all
    sudo mkisofs -D -r -V "ubuntu_MATE_16.04.1_LTS_X1000" -cache-inodes -J -l -o ../ubuntu-mate-16.04.1-desktop-powerpc-custom.iso .
  23. Code: Select all
    sudo cdrecord dev=/dev/cdrom ubuntu-mate-16.04.1-desktop-powerpc-custom.iso
After that I tried to load the ram disk with:
Unfortunately the CFE can't load the ram disk. I don't know why. I copied it to the CF card and after that I was able to load the ram disk.
CFE> ramdisk –addr=0x24000000 –fatfs cf0:initrd
I think I did something wrong with mkisofs.
OK, the integration of the xorg.conf was successfull. I can boot the Live DVD to the MATE desktop.
CFE> setenv bootargs "root=/dev/ramdisk file=/cdrom/preseed/ubuntu-mate.seed boot=casper quiet ro splash --"
I created a new ISO with:
sudo mkisofs -r -V "ubuntu_MATE_16.04.1_LTS_X1000" -iso-level 2 -o ../ubuntu-mate-16.04.1-desktop-powerpc-x1000.iso .
After that I burned it with Brasero. Unfortunately the CFE can't load the initrd.
Error message:
Loading: Error: DRQ should be zero
Had to read data 1024 times to clear DRQ
Failed.
Could not load atapi0.1:casper/powerpc64/initrd: File not found
But the CFE can see the initrd:
CFE> dir -fs=iso atapi0.1:CASPER/POWERPC64
INITRD. 24506574
VMLINUX. 27074136
OK, I see the problem. There is a dot at the end of the file name initrd.
CFE> ramdisk -addr=0x24000000 -fs=iso atapi0.1:casper/powerpc64/initrd.
works!!!!!!!!!!!!!
It boots to the MATE desktop without any problems.
I am happy! :-)
zappa2009
Post by zappa2009 »
Very cool.
I add vmlinux-4.7 into to root of the my UbuntuMate-X1000-LiveDVD and boot it from DVD only.
And I can mount my btrfs-exfat usbstick. I can access it on the Desktop :D
maybe its possible to add his modules too ;) But today its late. ;)
mechanic
Post by mechanic »
xeno74 wrote:Hi All,
I am happy! :-)
I have been monitoring your adventure with great interest.
Congratulations. :D
Congratulations. :D
Thank you! :-)
zappa2009 wrote:Very cool.
Well done! :-)
I also added the stable kernel 4.7.2 to the Live DVD and it boots to the MATE desktop with the following commands:
CFE> boot -elf -noints -fs=iso atapi0.1:casper/powerpc64/vmlinux.
It works without any problems.
Guys, we have a new Live DVD! :-)
mechanic
Post by mechanic »
WHOOPIE! :D
8-)
