LISTBROWSER_AutoVirtualWidth
mritter0
Post by mritter0 »
struct TextAttr			DejaVuSansMono14={ (STRPTR)"DejaVu Sans Mono.font",14,0,FPF_DISKFONT };
LAYOUT_AddChild,					Objects[GAD_PREVIEW_TEXT]=IIntuition->NewObject(ListBrowserClass,NULL,
	GA_ID,						GAD_PREVIEW_TEXT,
	GA_ReadOnly,				TRUE,
	GA_TextAttr,				&DejaVuSansMono14,
	LISTBROWSER_Borderless,		TRUE,
	LISTBROWSER_Labels,			PreviewTextList,
	LISTBROWSER_VerticalProp,	TRUE,
	LISTBROWSER_HorizontalProp,	TRUE,
	LISTBROWSER_AutoVirtualWidth,TRUE,
TAG_DONE),
I use this code to show text files with a monospaced font. When the text is wide, the horizontal scroller does not allow scrolling.
If I comment out the GA_TextAttr line and use the system proportional font, the horizontal scroller allows for scrolling like it should.
When I change text I use this
ILayout->SetPageGadgetAttrs((struct Gadget *)Objects[GAD_PREVIEW_TEXT],Objects[PAGE_PREVIEW_TEXT],MainWindow,NULL,
	LISTBROWSER_Top,			0,
TAG_DONE);
OS4.1FE
salass00
Re: LISTBROWSER_AutoVirtualWidth
Post by salass00 »
I would say that this is the same bug I fixed in version 53.67 of listbrowser.gadget (31.12.2015).
At least I'm not able to reproduce this on my beta system using a simple test program I put together.
mritter0
Post by mritter0 »
Working fine on a friend's system who is a beta tester, with newer OS than me.
