Issues with Radeon card for the Mediator
Benny
Post by Benny »
In the last months I bought 4 Radeon PCI card's for my Mediator 4000, but only the Sapphire Radeon 7000 with 64MB seems to work with OS4.1 FE.
The other 3 are:
ATI9200 / 128MB DDR PCI,
R92P 128MB PCI,
R9250PCI-D3 with 256MB.
With every card installed the machine keeps rebooting from the harddrive or from the OS4.1 FE disk/CD.
I think I tried every combination of jumpers on the Mediator PCI 4000 card.
Is the OS very picky about the card or is the videoram of 128MB an issue ?
DarrenHD
Re: Issues with Radeon card for the Mediator
Post by DarrenHD »
Benny wrote:In the last months I bought 4 Radeon PCI card's for my Mediator 4000, but only the Sapphire Radeon 7000 with 64MB seems to work with OS4.1 FE.
The other 3 are:
R92P 128MB PCI,
Do those other Radeons work on OS 3.x ?
I know the Sapphire card was tested and is confirmed to work as it is 5V Tolerant.
Benny
Post by Benny »
The other 3 are:
R92P 128MB PCI,
Non of the above cards work in the Mediator, I bought another Radeon PCI 9250 card and is does not work either under OS3.1: the PCIinfo (from Elbox) does not recognize the cards.
One of the cards is bought from a user with an Amiga 1200 Mediator.
Only the Radeon 7000, from my other topic, does work with OS4.1 FE, but not in the OS3.1 / 68060 / Mediator 4000 config.
The Cybervision 3D and the Voodoo 3000 do work under OS4.1 FE and the OS3.1 installation without any troubles, and stable.
So I guess I need another (tested in Mediator) Radeon 9250.
Benny
Post by Benny »
The other 3 are:
R92P 128MB PCI,
I bought 2 other Radeon's, I have a 3V and a 5V Mediator so every card should be ok, only not compatible to the os.
I now have 6 Radeon cards and 1 is working 100% in OS4.1 that is the Radeon 9250 from Sapphire. The 7000 from Sapphire has gfx glitches under OS4.1, but does run.
This Radeon 7000 does not work under OS3.1 and all my other 4 Radeon cards do not work in the Mediator either. A few are recognized in Pciinfo from Elbox, but they aren't running under Picasso96.
DarrenHD
Post by DarrenHD »
Benny wrote:
The other 3 are:
R92P 128MB PCI,
To be safe, at least for me the only Radeon's I've had work are ones purchased directly from Elbox, or the Sapphire Radeon 9250, either 128MB or 256MB.
Other Radeons may have different ID's which aren't picked up by the Radeon driver (they are hardcoded values and if they aren't there obviously it won't work).
