TimberWolf Optimization
Shamron
Post by Shamron »
I've tried several times to optimize Timberwolf, both through the settings in the menus, but also through about:config. Reducing disk cache size, writes, history age, etc.
I got a gut feeling that the reason TW so often bestowes us with a Grim Reaper on exit, are part due to the immensely intensive diskactivity/memory optimization.
Last time i used it, 3 days ago, it used 99% cpu, when just showing a blank page. If this is because it cleans up, optimizes or compresses the cache or whatever, but i've had less GR's at exit if i can time it to a point with low cpu usage.
I disabled the "correct typing errors as i write", i figure this hurts a bit at google.com, updating every time i type a new letter...
SO, anyone know of a good way to configure it? (using an X1000)
Re: TimberWolf Optimization
Assign T: to a hard drive directory instead of to RAM:T, that helped some at least on the stability back when I tried it, possibly also on the speed (don't remember exactly).
