HyperCom3+ and OS 4.1
Is there a way to get the parallel port of HyperCom3+ (zorro) to work with OS 4.1? I have tried with the v. 2.98 driver set/Mountlist for OS 3.x, and the HPR: is mounted, but cannot be opened when I try to print e.g. from PageStream 4.1. Is there any fix for this?
- DarrenHD
Re: HyperCom3+ and OS 4.1
Hi Gregor, unfortunately I don't think any of our beta testers have a HyperCom board, so I guess the answer is, I don't know.Gregor wrote:Is there a way to get the parallel port of HyperCom3+ (zorro) to work with OS 4.1? I have tried with the v. 2.98 driver set/Mountlist for OS 3.x, and the HPR: is mounted, but cannot be opened when I try to print e.g. from PageStream 4.1. Is there any fix for this?
Darren
I found a solution to the problem! The original mountlist needed just one extra line which I 'borrowed' from the dosdriver for 'PAR:'. There was also one line which did not have effect anymore so I commented it out.
I show the modifed list here: (It might also work with other HyperCom boards using hyperPAR.device)
/* Zorro II HyperCOM3 Z port-handler example mount entry for parallel port*/
EHandler = L:port-handler
Stacksize = 1024
Priority = 5
Device = hyperPAR.device
Unit = 0
/*Baud = 0 /* set this to ZERO for parallel.devices */*/
Control = "PAR"
Stacksize = 1024
Priority = 5
Unit = 0
Control = "PAR"
Re: HyperCom3+ and OS 4.1 [SOLVED]
Great work!Gregor wrote:I found a solution to the problem!
Maybe DarrenHD can put this solution in the FAQ...
- DarrenHD
I'll update itssolie wrote:Great work!Gregor wrote:I found a solution to the problem!
thanks for the report!
You should also be able to remap parallel.device to hyperPAR.device
Edit the Devs:NSDPatch.cfg
Add the line
DEVICE parallel.device UNIT 0 MAPTODEVICE hyperPAR.device UNIT 0 MACHINE=CLASSIC
Could you report back if that works too.
Add the line
Thanks for your advice! Unfortunately that patch does not seem to have any effect, at least in my machine... If I try to print to "PAR:" from PageStream, the busy-pointer stays there forever but nothing happens. And if I try to print e.g. from Notepad after having selected "parallel.device" instead of 'hyperPAR.device" in the Prefs/Printer, I get the messages "Make printer on-line" and "Error while printing! Error 1". The same messages come also without the patch-line in the 'NSDPatch.cfg', so obviously the patch does not direct the data to the hypercom port.JurassicC wrote:You should also be able to remap parallel.device to hyperPAR.device
Add the line
