Printer Prefs caused a yellow alert and crashed my system!
Hypex
Post by Hypex »
Was about to print using AmiPDF. My USB printer was on. Then I remembered last time I printed it came out black and white. So I went to open Printer Prefs to check my settings. And then I got this yellow alert. Soon after my system stopped working nomally with programs refusing to load. Why is it when the system goes funny you click on things and nothing happens?
So I rebooted and grabbed this log:
Hidden Text - Click to Show :
****************** Recoverable Alert ******************
Error: 0100000F Task: 0x5E846370
Dump of context at 0x020991B0
Trap type: DSI exception
Machine State (raw): 0x0000F030
Machine State (verbose): [ExtInt on] [User] [FPU on] [IAT on] [DAT on]
Temporary stack trace:
#0: in module Kickstart/kernel+0x00018C24 (0x01818C24)
#1: in module Kickstart/kernel+0x0003B688 (0x0183B688)
#2: in module Kickstart/kernel+0x0001A150 (0x0181A150)
#3: 0x7FFC2334
#4: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#5: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#6: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#7: 0x7FDF912C
#8: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#9: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#10: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#11: 0x7FDF912C
#12: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#13: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#14: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#15: 0x7FDF912C
#16: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#17: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#18: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#19: 0x7FDF912C
#20: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#21: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#22: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#23: 0x7FDF912C
#24: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#25: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#26: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#27: 0x7FDF912C
#28: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#29: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#30: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#31: 0x7FDFBA24
#32: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#33: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#34: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#35: 0x7F593458
#36: 0x7F5969F4
#37: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#38: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#39: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#40: 0x7FDF912C
#41: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#42: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#43: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#44: 0x7FDF912C
#45: in module Kickstart/intuition.library.kmod+0x00018178 (0x019ACBB8)
#46: in module Kickstart/intuition.library.kmod+0x0001839C (0x019ACDDC)
#47: in module Kickstart/intuition.library.kmod+0x00008424 (0x0199CE64)
#48: 0x7FDF012C
#49: 0x7CD209B8
#50: 0x7CD23218
#51: 0x7CD1E030
#52: in module Kickstart/dos.library.kmod+0x00020A14 (0x01926A14)
#53: in module Kickstart/kernel+0x000416F0 (0x018416F0)
#54: in module Kickstart/kernel+0x00041770 (0x01841770)
#55: 0x00000000
Crashed process: Printer (0x5E846370)
DSI verbose error description: Access not found in hash or BAT (page fault)
Access was a store operation
0: E1E1E1E1 503A0EB0 00000000 6083BE58 6083BE58 00000000 60A11196 00000000
8: 6083B894 E1E1E1E1 0000007E F7A1DF62 28824088 00000000 00000000 00000001
16: 00000001 503A1170 00000000 5F88D1E6 00000000 00000000 510F5868 00000000
24: 503A2A7C 609AC4B0 609AC4B0 00000000 00000000 00000008 00000008 6083B800
CR: 28828084 XER: 20000000 CTR: 01818C30 LR: 0183B598
DSISR: 42000000 DAR: E1E1E1E5
FP0 : 40DD40121212497D 005FE18DBE5E9A34 D10808DD08DD08D1 0000000000000000
FP4 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FP8 : 0000000000000000 BF60182436517A27 3ED0306CD997DDE4 BF5D4567DA2F09D8
FP12: 3FE0000000000000 0806080808400808 AC1BEFF7DAEAFCFA 3C9957BEC7EEEEDA
FP16: BE0BBD77F7D773F8 B8BFFFDED3DBFADF FEBF7BCEFBFBEEFF 3D33ABFF9DBBFE19
FP20: BA9BBFAE5EEFFE63 FA1B5FBE35FFFC16 3FDB13FA5FBAFEDC EFB59FD8BF55FDB2
FP24: 4C98E45E1DF3B012 33B011C2EAABE7D9 3FE0000000000000 4330000080000000
FP28: 4008000000000000 3FF3333340000000 41E0000000000000 408F400000000000
FPSCR: A6024100
Dump of context at 0xEF7727C0
#3: 0x7FFC2334
#7: 0x7FDF912C
#11: 0x7FDF912C
#15: 0x7FDF912C
#19: 0x7FDF912C
#23: 0x7FDF912C
#27: 0x7FDF912C
#31: 0x7FDFBA24
#35: 0x7F593458
#36: 0x7F5969F4
#40: 0x7FDF912C
#44: 0x7FDF912C
#48: 0x7FDF012C
#49: 0x7CD209B8
#50: 0x7CD23218
#51: 0x7CD1E030
#55: 0x00000000
FP0 : FFF80000A6024100 005FE18DBE5E9A34 D10808DD08DD08D1 0000000000000000
FPSCR: A6024100
Registers pointing to code:
ip : module Kickstart/kernel at 0x01818C24 (section 0 @ 0x18C28)
lr : module Kickstart/kernel at 0x0183B598 (section 0 @ 0x3B59C)
ctr: module Kickstart/kernel at 0x01818C30 (section 0 @ 0x18C34)
Stack Backtrace:
(0x503A0EB0) module Kickstart/kernel at 0x01818C24 (section 0 @ 0x18C28)
(0x503A0EC0) module Kickstart/kernel at 0x0183B688 (section 0 @ 0x3B68C)
(0x503A0EE0) module Kickstart/kernel at 0x0181A150 (section 0 @ 0x1A154)
(0x503A0F00) module CLASSES:gadgets/button.gadget at 0x7FFC2334 (section 5 @ 0x3314)
(0x503A0FD0) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A1030) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A10B0) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A10C0) module CLASSES:gadgets/layout.gadget at 0x7FDF912C (section 5 @ 0xA10C)
(0x503A1260) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A12C0) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A1340) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A1350) module CLASSES:gadgets/layout.gadget at 0x7FDF912C (section 5 @ 0xA10C)
(0x503A14F0) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A1550) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A15D0) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A15E0) module CLASSES:gadgets/layout.gadget at 0x7FDF912C (section 5 @ 0xA10C)
(0x503A1780) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A17E0) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A1860) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A1870) module CLASSES:gadgets/layout.gadget at 0x7FDF912C (section 5 @ 0xA10C)
(0x503A1A10) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A1A70) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A1AF0) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A1B00) module CLASSES:gadgets/layout.gadget at 0x7FDF912C (section 5 @ 0xA10C)
(0x503A1CA0) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A1D00) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A1D80) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A1D90) module CLASSES:gadgets/layout.gadget at 0x7FDF912C (section 5 @ 0xA10C)
(0x503A1F30) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A1F90) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A2010) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A2020) module CLASSES:gadgets/layout.gadget at 0x7FDFBA24 (section 5 @ 0xCA04)
(0x503A20A0) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A2100) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A2180) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A2190) module CLASSES:gadgets/clicktab.gadget at 0x7F593458 (section 5 @ 0x2438)
(0x503A2290) module CLASSES:gadgets/clicktab.gadget at 0x7F5969F4 (section 5 @ 0x59D4)
(0x503A23F0) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A2450) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A24D0) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A24E0) module CLASSES:gadgets/layout.gadget at 0x7FDF912C (section 5 @ 0xA10C)
(0x503A2680) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A26E0) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A2760) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A2770) module CLASSES:gadgets/layout.gadget at 0x7FDF912C (section 5 @ 0xA10C)
(0x503A2910) module Kickstart/intuition.library.kmod at 0x019ACBB8 (section 0 @ 0x1817C)
(0x503A2970) module Kickstart/intuition.library.kmod at 0x019ACDDC (section 0 @ 0x183A0)
(0x503A29F0) module Kickstart/intuition.library.kmod at 0x0199CE64 (section 0 @ 0x8428)
(0x503A2A00) module CLASSES:gadgets/layout.gadget at 0x7FDF012C (section 5 @ 0x110C)
(0x503A2B10) module Printer at 0x7CD209B8 (section 5 @ 0x2998)
(0x503A2CB0) module Printer at 0x7CD23218 (section 5 @ 0x51F8)
(0x503A2F80) Printer:_start()+0x10 (section 1 @ 0x10)
(0x503A2F90) module Kickstart/dos.library.kmod at 0x01926A14 (section 0 @ 0x20A18)
(0x503A2FC0) module Kickstart/kernel at 0x018416F0 (section 0 @ 0x416F4)
(0x503A2FD0) module Kickstart/kernel at 0x01841770 (section 0 @ 0x41774)
(0x503A2FE0)
Disassembly of crash site:
01818C14: 800B0000 lwz r0,0(r11)
01818C18: 90030000 stw r0,0(r3)
01818C1C: 812B0000 lwz r9,0(r11)
01818C20: 800B0004 lwz r0,4(r11)
>01818C24: 90090004 stw r0,4(r9)
01818C28: 7D635B78 mr r3,r11
01818C2C: 4E800020 blr
01818C30: 7C832378 mr r3,r4
01818C34: 4BFFFFCC b 0x1818C00
01818C38: 81630000 lwz r11,0(r3)
Stack pointer (0x503A0EB0) is inside bounds
Redzone is OK (4)
68k register dump
ADDR: 00000000
Re: Printer Prefs caused a yellow alert and crashed my syst
Is this repeatable?
Needles to say it doesn't crash for me.
If it's not repeatable it could be the result of some other prgram crashing / corrupting memory. Had there been anyother GR's in that session?
How did you open the printer prefs from workbench? Shell? via amipdf ? (not sure if you can do the last anyway)
ssolie
Post by ssolie »
He can now file a proper bug report and work from there...
broadblues wrote:Is this repeatable?
I can confirm the crash. Try selecting the AmiPDF Project/Print menu to open the "Print setup" window before starting the Printer Prefs program. I got one of those OS3 looking Guru windows at the top of my screen and when I clicked the mouse button the middle of the screen filled with graphics corruption. Maybe any program having the printer.device open when Printer Prefs is launched would cause this problem. Haven't had time to test.
@Hypex
If you file a bug report be sure to make it clear that the AmiPDF "Print setup" window was open before opening Printer Prefs. I didn't have any problem with just AmiPDF open and starting Printer Prefs.
