So, what can I stick into the PCI slot on a MicroA1 board?
Mikey_C
Post by Mikey_C »
Hi guys, looking for advice on this, yes, I know, its an old board, yes, I should upgrade, etc, etc.
But please indulge an old time amiga user, can anyone here give me a list of what I can use in that PCI slot? What works? what doesn't?
I would love to get USB 2.0 working on it, however reading some old threads, I wasn't able to work out if the problems with the EHCI driver had been fixed to allow USB 2.0 to work.
If it has been fixed, which low profile card would be recommended?
I believe a graphics card is still a no no though, so I am limited there.
SATA/Hard drives Card?
Any advice on this topic, greatly appreciated
Mikey C
davebraco
Re: So, what can I stick into the PCI slot on a MicroA1 boar
Post by davebraco »
I did use a PATA-Pci Card, then a gigabit ethernet card and finaly a SATA card.
Never got any chance with USB2 cards, but the SATA card had an external port so I could plug external harddrive.
Maybe you can plug a catweasel card if there is a need for oldskool stuff.
LyleHaze
Post by LyleHaze »
I tried many different USB2 cards, I never had any success.
I'm not saying it can't be done, just that mine never went there.
sailorMH
Post by sailorMH »
davebraco wrote: Fri May 20, 2016 8:33 pm I did use a PATA-Pci Card, then a gigabit ethernet card and finaly a SATA card.
Please, can you share exact type of your 1 GbE card working in MicroA1-C? Photo will be great.
I tried two cards with my Micro with no success ( one of them works for sure with AmigaOS on X1000 ).
Sata card also works for me.
