Kernel 4.7
Kernel 4.7
The first alpha of kernel 4.7 is available for testing. :-)
- Phoronix articles, reviews and news stories covering Linux 4.7
- Linux Git log
Download: vmlinux-4.7-alpha1-AmigaONE_X1000.tar.gz
openSUSE Tumbleweed PPC64 with the alpha1 of kernel 4.7:
Re: Kernel 4.7
The alpha2 is available for testing.
Download: vmlinux-4.7-alpha2-AmigaONE_X1000.tar.gz
The alpha2 with openSUSE Tumbleweed PPC64:
Re: Kernel 4.7
The old kernel 4.6 Nemo patch doesn't work anymore. I created a new Nemo patch for the alpha3 today. :-)
Download: nemo_4.7-1.patch
Re: Kernel 4.7
A new alpha version is available. :-)
Download: vmlinux-4.7-alpha3-AmigaONE_X1000.tar.gz
Please test the alpha3.
Thanks in advance,
Re: Kernel 4.7
I tried to compile the alpha4 today.
I got the following error message during the building process:
arch/powerpc/kernel/pci-common.c: In function ‘pci_process_bridge_OF_ranges’:
arch/powerpc/kernel/pci-common.c:732:59: error: ‘_PAGE_GUARDED’ undeclared (first use in this function)
                                range.size, _PAGE_NO_CACHE|_PAGE_GUARDED);
arch/powerpc/kernel/pci-common.c:732:59: note: each undeclared identifier is reported only once for each function it appears in
make[1]: *** [arch/powerpc/kernel/pci-common.o] Fehler 1
make: *** [arch/powerpc/kernel] Fehler 2
_PAGE_GUARDED is used in our Nemo patch:
+#ifdef CONFIG_PPC_PASEMI_SB600
+                       /* Workaround for lack of device tree. New for kernel 3.17: range.cpu_addr instead of cpu_addr and range.size instead of size Ch. Zigotzky */
+                       if (primary) {
+                               __ioremap_at(range.cpu_addr, (void *)ISA_IO_BASE,
+                               range.size, _PAGE_NO_CACHE|_PAGE_GUARDED);
+                       hose->io_base_virt = (void *)_IO_BASE;
+               /* _IO_BASE needs unsigned long long for the kernel 3.17 Ch. Zigotzky */
+                       printk("Initialised io_base_virt 0x%lx _IO_BASE 0x%llx\n", (unsigned long)hose->io_base_virt, (unsigned long long)_IO_BASE);
+#endif
It was deleted with the PowerPC updates powerpc-4.7-1 on 2016-05-20 17:12:41 (GMT).
diff --git a/arch/powerpc/include/asm/book3s/64/hash.h b/arch/powerpc/include/asm/book3s/64/hash.h
index d0ee6fc..f61cad3 100644
--- a/arch/powerpc/include/asm/book3s/64/hash.h
+++ b/arch/powerpc/include/asm/book3s/64/hash.h
@@ -13,48 +13,12 @@
  * We could create separate kernel read-only if we used the 3 PP bits
  * combinations that newer processors provide but we currently don't.
-#define _PAGE_BIT_SWAP_TYPE    0
-#define _PAGE_EXEC        0x00001 /* execute permission */
-#define _PAGE_RW        0x00002 /* read & write access allowed */
-#define _PAGE_READ        0x00004    /* read access allowed */
-#define _PAGE_USER        0x00008 /* page may be accessed by userspace */
-#define _PAGE_GUARDED        0x00010 /* G: guarded (side-effect) page */
I modify the line
to
range.size, pgprot_val(pgprot_noncached(__pgprot(0))));
After that it compiled without any problems but unfortunately it doesn't boot.
Re: Kernel 4.7
I deleted our device tree patch from the Nemo patch and after that I compiled the kernel again. Unfortunately the kernel doesn't boot from CFE.
Re: Kernel 4.7
I removed the variable _PAGE_GUARDED from the Nemo patch. It compiled but nevertheless the kernel doesn't boot.
The last message from CFE:
Booting Linux via __start()...
Re: Kernel 4.7
I added #define _PAGE_GUARDED 0x00010 /* G: guarded (side-effect) page */ to our Nemo patch.
    +                       #define _PAGE_GUARDED        0x00010 /* G: guarded (side-effect) page */
    +                       if (primary) {
    +#endif
It compiled but it doesn't boot either.
After Booting Linux via __start()... it happens nothing.
Re: Kernel 4.7
I have found range.size in the old pSeries PCI code as well.
Link: pSeries_pci.c
Re: Kernel 4.7
FYI:
Benjamin Herrenschmidt wrote: On Mon, 2016-05-23 at 06:38 +0200, Christian Zigotzky wrote:
> Hi All,
> You removed PAGE_GUARDED in the commit
> https://git.kernel.org/cgit/linux/kerne ... 9cdffd44a6
> We use
> This doesn't work anymore. What can we use instead?
You should just use pgprot_noncached()
Ben.
