Installing SSD in MicroA1-C (Stuck)
Mikey_C
Post by Mikey_C »
Apologies, but this is a cross thread from Amigans.net - I am looking for the best advice please
Hi Guys
Long story, but basically, I am trying to install AmigaOS4.1 FE onto my Micro Amigaone (after 5 hours of trying, an IDE/SSD adapter with an IDE/Laptop Drive adapter (Turns out they don't like each other)
I have gotten to a point where I have the IDE/SATA/SSD adapter and an old IDE DVD Drive on the same cable, working to allow me to install OS4.1 FE.
Okay, I know this is going to sound STUPID! But in MediaToolbox, for the SSD Drive (it says no A1 Booter Installed) When I click on Install it takes me to L: Do I select slb_v2?
Any help or advice with installing the SSD, much appreciated!!!
Re: Installing SSD in MicroA1-C (Stuck)
Yes. it then copies that file from L: to the RDB of the disk (in this case the SSD). You need it there to boot the device.
