AmiUpdate Error
jdupuis
AmiUpdate Error
Post by jdupuis »
Do not know if it has been addressed. AmiUpdate has given the following error the past couple of days after clicking Scan:
Error parsing database file
Line 46: Unterminated string value
[Abort]
Just thought I'd report it. I've not seen this one before. Usually errors are corrected pretty quick. It's happening on both my X1000 and Sam460ex AOS 4.1 FE installs.
Cheers!!
ddni
Re: AmiUpdate Error
Post by ddni »
I have the same problem.
I have seen this before. IIRC it is a server error at update.amigaos.net
