Hi!
I would know on classic Workbench but not sure in AOS 4.1 on the X1000.
When I Boot up into AOS after shutdown of Ubuntu I have to re-save System Time in Prefs. Is there a simple line I can add to User-Startup to Update system time on Boot Up?
I'm using Internet Time Server and Offset is "Auto"
Cheers!!
AOS System Clock - Simple Question [SOLVED]
Re: AOS System Clock - Simple Question
Not to User-Startup, but to Network-Startup, after the lines that establish your network connection (so you are sure you have network access when you try fetching the time). The line is:jdupuis wrote:Is there a simple line I can add to User-Startup to Update system time on Boot Up?
Date SERVER PREFS
You can follow that with a Setclock SAVE if you want, but you might not want to bother, since the system time will be changed again the next time you boot into Linux anyway.
Provided you have saved the Time prefs with the time server info set like that, the above line(s) added to Network-Startup will do what you want.I'm using Internet Time Server and Offset is "Auto"
Thank you very much, Niels.
Cheers!!
John
Cheers!!
John
