Kernel 4.6
Kernel 4.6
Linus has already pulled the latest set of patches from some branches for the kernel 4.6, so I released the alpha1 for testing today.
Download: vmlinux-4.6-alpha1-AmigaONE_X1000.tar.gz
Regards,
Re: Kernel 4.6
Linus Torvalds added some new source code for the kernel 4.6 to the Linux Git last night.
New: Linux Git log
I created the alpha2 from the latest Git source code today.
Download: vmlinux-4.6-alpha2-AmigaONE_X1000.tar.gz
Would you mind testing it? For me it would be interesting, if the P.A. Semi Ethernet works.
Re: Kernel 4.6
FYI: The old Nemo patch 4.5-9 doesn't work anymore. You need the new Nemo patch 4.6-1 instead.
Download: nemo_4.6-1.patch
Re: Kernel 4.6
Post by zzd10h »
Works fine here :
Re: Kernel 4.6
zzd10h wrote:Works fine here :
Thank you for testing.
I'm compiling the alpha3 but there is a problem with compiling the kvm-pr kernel module.
Building modules, stage 2.
  MODPOST 29 modules
ERROR: ".kvmppc_h_put_tce" [arch/powerpc/kvm/kvm-pr.ko] undefined!
ERROR: ".kvmppc_h_stuff_tce" [arch/powerpc/kvm/kvm-pr.ko] undefined!
make[1]: *** [__modpost] Fehler 1
make: *** [modules] Fehler 2
Re: Kernel 4.6
Yesterday, I tested the alpha2. I was able to compile the kvm-pr kernel module yesterday. After that I successfully tested it with Mac-on-Linux and Mac OS X Tiger yesterday.
I think the problem is in the latest KVM updates. Link: Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm
I wrote an email to the kvm-ppc mailing list today.
Re: Kernel 4.6
I released the alpha3 without the kvm-pr kernel module today.
Download: vmlinux-4.6-alpha3-AmigaONE_X1000.tar.gz
I wasn't able to compile the kvm-pr kernel module because there is something wrong in the source code. I think the problem is in the latest KVM updates.
Link: Merge tag for-linus of git://git.kernel.org/pub/scm/virt/kvm/kvm.
The kvm-pr kernel module from the alpha2 works without any problems. I tested it with Mac-on-Linux and Mac OS X Tiger yesterday.
I informed the developers about this problem via two mailing lists, today.
Links:
List kvm-ppc
List kvm-general
Re: Kernel 4.6
I have some good news because of the kvm-pr issue. :-)
Paolo Bonzini wrote: Paul and Alexey, can you take a look? I guess I can figure it out, but
let's use the timezone difference to our advantage for once. :-)
Paolo
Alexey Kardashevskiy wrote: The missing handlers are only compiled when HV KVM is enabled, I made this change in the very last respin of my patchset after a comment that having duplicated code is bad and this happened right before it was pulled to Paul's tree. My bad, apologies... I'll post a fix soon.
Alexey
Alexey Kardashevskiy wrote: Upcoming in-kernel VFIO acceleration needs different handling in real and virtual modes which makes it hard to support both modes in the same handler.
This creates a copy of kvmppc_rm_h_stuff_tce and kvmppc_rm_h_put_tce in addition to the existing kvmppc_rm_h_put_tce_indirect.
This also fixes linker breakage when only PR KVM was selected (leaving HV KVM off): the kvmppc_h_put_tce/kvmppc_h_stuff_tce functions would not compile at all and the linked would fail.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
 arch/powerpc/kvm/book3s_64_vio.c        | 52 +++++++++++++++++++++++++++++++++
 arch/powerpc/kvm/book3s_64_vio_hv.c     |  8 ++---
 arch/powerpc/kvm/book3s_hv_rmhandlers.S |  4 +--
 3 files changed, 57 insertions(+), 7 deletions(-)
diff --git a/arch/powerpc/kvm/book3s_64_vio.c b/arch/powerpc/kvm/book3s_64_vio.c
index 2c2d103..75469f6 100644
--- a/arch/powerpc/kvm/book3s_64_vio.c
+++ b/arch/powerpc/kvm/book3s_64_vio.c
@@ -209,6 +209,32 @@ fail:
 	return ret;
+long kvmppc_h_put_tce(struct kvm_vcpu *vcpu, unsigned long liobn,
+		      unsigned long ioba, unsigned long tce)
+	struct kvmppc_spapr_tce_table *stt = kvmppc_find_table(vcpu, liobn);
+	long ret;
+	/* udbg_printf("H_PUT_TCE(): liobn=0x%lx ioba=0x%lx, tce=0x%lx\n", */
+	/* 	    liobn, ioba, tce); */
+	if (!stt)
+		return H_TOO_HARD;
+	ret = kvmppc_ioba_validate(stt, ioba, 1);
+	if (ret != H_SUCCESS)
+		return ret;
+	ret = kvmppc_tce_validate(stt, tce);
+		return ret;
+	kvmppc_tce_put(stt, ioba >> stt->page_shift, tce);
+	return H_SUCCESS;
+EXPORT_SYMBOL_GPL(kvmppc_h_put_tce);
 long kvmppc_h_put_tce_indirect(struct kvm_vcpu *vcpu,
 		unsigned long liobn, unsigned long ioba,
 		unsigned long tce_list, unsigned long npages)
@@ -264,3 +290,29 @@ unlock_exit:
 	return ret;
 EXPORT_SYMBOL_GPL(kvmppc_h_put_tce_indirect);
+long kvmppc_h_stuff_tce(struct kvm_vcpu *vcpu,
+		unsigned long liobn, unsigned long ioba,
+		unsigned long tce_value, unsigned long npages)
+	struct kvmppc_spapr_tce_table *stt;
+	long i, ret;
+	stt = kvmppc_find_table(vcpu, liobn);
+	if (!stt)
+	ret = kvmppc_ioba_validate(stt, ioba, npages);
+		return ret;
+	/* Check permission bits only to allow userspace poison TCE for debug */
+	if (tce_value & (TCE_PCI_WRITE | TCE_PCI_READ))
+		return H_PARAMETER;
+	for (i = 0; i < npages; ++i, ioba += (1ULL << stt->page_shift))
+		kvmppc_tce_put(stt, ioba >> stt->page_shift, tce_value);
+	return H_SUCCESS;
+EXPORT_SYMBOL_GPL(kvmppc_h_stuff_tce);
diff --git a/arch/powerpc/kvm/book3s_64_vio_hv.c b/arch/powerpc/kvm/book3s_64_vio_hv.c
index 44be73e..18f0227 100644
--- a/arch/powerpc/kvm/book3s_64_vio_hv.c
+++ b/arch/powerpc/kvm/book3s_64_vio_hv.c
@@ -180,8 +180,8 @@ long kvmppc_gpa_to_ua(struct kvm *kvm, unsigned long gpa,
 EXPORT_SYMBOL_GPL(kvmppc_gpa_to_ua);
 #ifdef CONFIG_KVM_BOOK3S_HV_POSSIBLE
-long kvmppc_h_put_tce(struct kvm_vcpu *vcpu, unsigned long liobn,
-		      unsigned long ioba, unsigned long tce)
+long kvmppc_rm_h_put_tce(struct kvm_vcpu *vcpu, unsigned long liobn,
 	long ret;
@@ -204,7 +204,6 @@ long kvmppc_h_put_tce(struct kvm_vcpu *vcpu, unsigned long liobn,
 	return H_SUCCESS;
-EXPORT_SYMBOL_GPL(kvmppc_h_put_tce);
 static long kvmppc_rm_ua_to_hpa(struct kvm_vcpu *vcpu,
 		unsigned long ua, unsigned long *phpa)
@@ -296,7 +295,7 @@ unlock_exit:
 	return ret;
-long kvmppc_h_stuff_tce(struct kvm_vcpu *vcpu,
+long kvmppc_rm_h_stuff_tce(struct kvm_vcpu *vcpu,
@@ -320,7 +319,6 @@ long kvmppc_h_stuff_tce(struct kvm_vcpu *vcpu,
 	return H_SUCCESS;
-EXPORT_SYMBOL_GPL(kvmppc_h_stuff_tce);
 long kvmppc_h_get_tce(struct kvm_vcpu *vcpu, unsigned long liobn,
 		      unsigned long ioba)
diff --git a/arch/powerpc/kvm/book3s_hv_rmhandlers.S b/arch/powerpc/kvm/book3s_hv_rmhandlers.S
index 85b32f1..81b0b51 100644
--- a/arch/powerpc/kvm/book3s_hv_rmhandlers.S
+++ b/arch/powerpc/kvm/book3s_hv_rmhandlers.S
@@ -1942,7 +1942,7 @@ hcall_real_table:
 	.long	DOTSYM(kvmppc_h_clear_ref) - hcall_real_table
 	.long	DOTSYM(kvmppc_h_protect) - hcall_real_table
 	.long	DOTSYM(kvmppc_h_get_tce) - hcall_real_table
-	.long	DOTSYM(kvmppc_h_put_tce) - hcall_real_table
+	.long	DOTSYM(kvmppc_rm_h_put_tce) - hcall_real_table
 	.long	0		/* 0x24 - H_SET_SPRG0 */
 	.long	DOTSYM(kvmppc_h_set_dabr) - hcall_real_table
 	.long	0		/* 0x2c */
@@ -2020,7 +2020,7 @@ hcall_real_table:
 	.long	0		/* 0x12c */
 	.long	0		/* 0x130 */
 	.long	DOTSYM(kvmppc_h_set_xdabr) - hcall_real_table
-	.long	DOTSYM(kvmppc_h_stuff_tce) - hcall_real_table
+	.long	DOTSYM(kvmppc_rm_h_stuff_tce) - hcall_real_table
 	.long	DOTSYM(kvmppc_rm_h_put_tce_indirect) - hcall_real_table
 	.long	0		/* 0x140 */
 	.long	0		/* 0x144 */
2.5.0.rc3
