Would like to see right-click "Eject" on external USB devices as eject would wait for tasks to complete to inform that device is safe to remove. ( Yeah, I know, more GUI stuff )
Cheers!!
John
USB Devices "Eject"
USB Devices "Eject"
Re: USB Devices "Eject"
Use the "DisMount" command?
(edit)
Sorry, that isn't going to work, another reference to the device will simply mount it again.
(/edit)
(edit)
(/edit)
Yes, "DisMount" works. So does the Eject Button in Media ToolBox. That being said, I thought it would be a nice shortcut to include in the Right-Click Menu when right clicking on the USB Thumbdrive or External USB HDD Icon instead of opening up Shell and such. It was just a thought. Thanks.tonyw wrote:Use the "DisMount" command?
(edit)
(/edit)
Cheers!!
- thomasrapp
There are thousands of Eject programs on Aminet, just use one of them.
But Eject is by far not a "safe remove". It's the same as removing the drive, just programmaticaly. It does not wait for anything to finish.
Belxjander
My own personal option is to stop all programs accessing the USB device, and then apply the "C:DiskChange" command to it ...before hot-removal
This usually forces the filesystem to flush caches and sync the USB device afaik
the only time I have run into errors with this was 3 identical USB sticks where only the serial numbers differed.
- salass00
I don't recall exactly what DiskChange does but assuming it's just inhibit/uninhibit then it should do just that.Belxjander wrote:My own personal option is to stop all programs accessing the USB device, and then apply the "C:DiskChange" command to it ...before hot-removal
Dismount is better though if the filesystem supports it.
Belxjander
salass00 wrote:I don't recall exactly what DiskChange does but assuming it's just inhibit/uninhibit then it should do just that.Belxjander wrote:My own personal option is to stop all programs accessing the USB device, and then apply the "C:DiskChange" command to it ...before hot-removal
Well this would mean that "C:DiskChange <DOSdriver>:" followed by "C:Dismount <DOSdriver>:" would work within an ARexx script
given usage of "ContextMenus" and "Workbench ARexx" features being present
Anyone want to give that idea a go? maybe throw it on os4depot.net or provide it as an OS ARexx script for just such a purpose?
Personally I need to deal with force-reloading the USB stack when a heartbeat fails as I run into breaking it often having many USB sticks only different by serial codes.
- Daedalus
I've just given it a go, and it doesn't work. Well, it sort of works, but the Dismount permanently dismounts the device, meaning that it won't mount again until you reboot. I tried using Dismount USB0:, which removed the device but even removing the drive and plugging it into a different USB socket wouldn't make it reappear. Doing a Dismount VolumeName: doesn't work, and using Dismount USB0: SOFT means that the drive simply remounts a couple of seconds later, similar to how Diskchange USB0: behaves.Belxjander wrote:Well this would mean that "C:DiskChange <DOSdriver>:" followed by "C:Dismount <DOSdriver>:" would work within an ARexx script
It seems like it might need a custom little tool that disables a device until it's removed, then resets to normal. Anyone got any ideas of a simple way of achieving this?
Belxjander
Then an Equivalent action to the Eject/Inject functionality shown in MediaToolbox for optical drives with commands to match?Daedalus wrote:I've just given it a go, and it doesn't work. Well, it sort of works, but the Dismount permanently dismounts the device, meaning that it won't mount again until you reboot. I tried using Dismount USB0:, which removed the device but even removing the drive and plugging it into a different USB socket wouldn't make it reappear. Doing a Dismount VolumeName: doesn't work, and using Dismount USB0: SOFT means that the drive simply remounts a couple of seconds later, similar to how Diskchange USB0: behaves.Belxjander wrote:Well this would mean that "C:DiskChange <DOSdriver>:" followed by "C:Dismount <DOSdriver>:" would work within an ARexx script
This is already part of the trackdisk/scsi device driver specs from older OS versions... Can we reuse that for this USB functionality?
