Gorky 17 and AmigaOne G3 SE
macce2
Post by macce2 »
Hello everybody,
I'm new here and posted this message here, because I can't access the Gorky 17 topic of Games section.
I have AmigaOne SE with G3 running @600MHz with OS 4.1FE installed.
I would like to know, if Gorky 17 is supposed to run on my machine, before I buy it ? :-o
So, has anyone tried this game with AmigaOne SE ?
I have Radeon 9250 graphics card installed and SB Live soundcard. Memory 512 MB installed.
Re: Gorky 17 and AmigaOne G3 SE
Technical Requirements - Amiga Version
Amiga with 500MHz PowerPC CPU
A Picasso96-Compatible Graphics card (For Warp3D version: A Warp3D supported graphics card)
256 MB of memory
AHI-Compatible sound card
8x or better CD-ROM.
Approximately 700 MB of free harddisk space
AmigaOS 4.1 Final Edition
You should be good
macce2
Post by macce2 »
Yeah, I bought Gorky 17 some time ago, and it works..but while loading different parts of the game (menus, etc)
the sound becomes distorted/clips. Maybe it has to do with the dma settings of the hard drive ?!
The problem is, because I can't get IDETOOL to recognize my devices (SII Ide Raid pci card),
I must guess the correct setting in Uboot (currently dma0) ?!
:shock:
Evillord68
Post by Evillord68 »
Do you use software render or hardware render?
macce2
Post by macce2 »
Hardware renderer.
Btw, yesterday, when trying different dma mode settings (uboot), by AmigaOne won't boot anymore.
It freezes soon after black screen with text "Amiga os 4.1 FE" appears.
I tried to boot from cd(-s), but I get plenty of "volume x has a read /write error" reguesters and I've been busy clicking them away.. :-o I managed to boot with os4 Final cd, but then the system locked up somehow..
Help! A bit off topic, (sorry, moderators) , but Is there a way to change the dma mode settings from uboot "console" ?
setenv command ?? :-o
javierdlr
Post by javierdlr »
macce2 wrote:Hardware renderer.
If you mean the Uboot 'sii0680ide_xfer' envvar (or 'a1ide_xfer') just remove/delete such envvar
I - Configuring sii680ide through UBOOT envvars
- sii0680ide_xfer
Allows to define the xfer mode which will be used for each drive. Compose
4 chars (prim master, prim slave, sec master, sec slave) using :
0 - Automatic PIO (driver will use the best PIO mode
that the drive claims to support)
a - PIO 0 ( 3 MB/s, modeid 8)
b - PIO 1 ( 5 MB/s, modeid 9)
c - PIO 2 ( 8 MB/s, modeid 10)
d - PIO 3 ( 11 MB/s, modeid 11)
e - PIO 4 ( 16 MB/s, modeid 12)
A - UDMA 0 ( 16 MB/s, modeid 64)
B - UDMA 1 ( 25 MB/s, modeid 65)
C - UDMA 2 ( 33 MB/s, modeid 66)
D - UDMA 3 ( 44 MB/s, modeid 67)
E - UDMA 4 ( 66 MB/s, modeid 68)
F - UDMA 5 (100 MB/s, modeid 69)
G - UDMA 6 (133 MB/s, modeid 70)
NB : sii0680ide will fall back to the best mode that the drive claims to support
in case you ask for an unsupported mode.
Default : if you don't set this envvar, sii0680ide will use the best PIO mode
supported by the drive.
- sii0680ide_irq
Compose 4 chars (prim master, prim slave, sec master, sec slave) using :
1 : use IRQs
any other char : don't use IRQs
Default : if you don't set this envvar, sii0680ide WILL use interrupts.
macce2
Post by macce2 »
Than you for information,
but I think the boot volume of my system has become unvalidated, and it needs to be validated somehow, but don't know how. I use FFS International with long names. The system partition has OS 4.1FE installed. I have replaced some files (sii_xxx.device.kmod ??!) from the Kickstart drawer, and deleted USB related file(S).
I managed to boot from OS 4.1F cd, but Partitionwizard doesn't see the partitions (there are 4 + Swap) properly.
It worked with DMA Mode 4 before, but after experimenting with DMA Mode 6 my system stopped working.. :|
javierdlr
Post by javierdlr »
macce2 wrote:Than you for information,
but I think the boot volume of my system has become unvalidated, and it needs to be validated somehow, but don't know how. I use ...
Check hdd/ide cables if they are well fitted.
The (file)system should auto-validate itself. Just try to boot without startup-squence (via early boot menu) and type 'c:info' it should show your volumes status (readonly, r/w, validating,...).
And if PW doesn't see parttions maybe bootblock is screwed/damaged :-/ then no idea how to solve it.
macce2
Post by macce2 »
Thanks for help, I think my cables should be ok. But I didn't know AONE SE did have a boot menu, did it ?! :-o
I think I don't know how to boot without ss with AONE SE board..
I have also Amiga 4000D and I can access bootmenu with it.
I hope the bootblock isn't damaged.
macce2 wrote:Thanks for help, I think my cables should be ok. But I didn't know AONE SE did have a boot menu, did it ?! :-o
Not sure if it works for your hardware, but try keep pressing both mouse buttons while the system boots, "normally" it should bring you straight into Early Startup.
