strcasecmp()
kas1e
strcasecmp()
Post by kas1e »
Plz, add strcasecmp() to the newlib. It already present in clib2, but also necessary to have it in newlib as well. I can of course create my own custom one, but that function from time to time need it.
salass00
Re: strcasecmp()
Post by salass00 »
The function strcasecmp() is implemented in newlib but is disabled for __STRICT_ANSI__ code.
If your code is compiled with -std=c99 you will want to change it to -std=gnu99.
kas1e
Re: strcasecmp()
Post by kas1e »
I tried to compile it with g++ and std=c++11 , so:
> ppc-amigaos-g++ -std=c++11 -c test.c -o test.o
test.c: In function 'int main()':
test.c:30:19: error: 'strcasecmp' was not declared in this scope
And if:
> ppc-amigaos-g++ -std=c++11 -std=gnu99 -c test.c -o test.o
cc1plus: warning: command line option '-std=gnu99' is valid for C/ObjC but not for C++
But i need -std=c++11.
salass00
Re: strcasecmp()
Post by salass00 »
Use -std=gnu++11 instead.
