Dummy audio Ahi
tlosmx
Dummy audio Ahi
Post by tlosmx »
I found have this can be really useful .in my testing i see if you dont have a mixer up many programs crash because need an audio working
LyleHaze
Re: Dummy audio Ahi
Post by LyleHaze »
I am confused.
Mixer is not part of the OS, and it has nothing to do with AHI either.
It works by manipulating the registers of the sound card directly.
tlosmx
Re: Dummy audio Ahi
Post by tlosmx »
yes it comes with some . example on quakegl
or exit alone on amigaracer
salass00
Re: Dummy audio Ahi
Post by salass00 »
A VOID driver like exists on AROS would be useful for computers that don't have a supported audio card installed.
Re: Dummy audio Ahi
Could something like that be done with FileSave and NIL:?
Re: Dummy audio Ahi
salass00 wrote:A VOID driver like exists on AROS would be useful for computers that don't have a supported audio card installed.
VOID is a standard example in the AHI sdk, so all it needs is someone to build it.
void.lha
VOID driver for amigaos4
(217.29 KiB) Downloaded 578 times
salass00
Re: Dummy audio Ahi
Post by salass00 »
broadblues wrote: VOID is a standard example in the AHI sdk, so all it needs is someone to build it.
I'm aware of that (I checked my AHI SVN checkout before posting). It doesn't necessarily mean it will/would compile without any changes having to be made first though.
tlosmx
Re: Dummy audio Ahi
Post by tlosmx »
Thanks guys it is working :)
