ListBroswer checkbox
mritter0
Post by mritter0 »
I would like to be able to enable/disable the checkboxes in a listbrowser node. Making it ReadOnly is not what I need. I still want to be able to select the item, just not change the checked state.
IListBrowser->SetListBrowserNodeAttrs(SelNode,
    LBNA_CheckBoxDisabled,    TRUE,
TAG_DONE);
Probably all types of gadgets could make use of this.
It would also be nice for when a node is ReadOnly, to also give the text the disabled look, by option
    LBNA_Disabled,   TRUE,
TAG_DONE);
So the user visually sees it is not selectable. This would also disable any gadgets associated with it.
Re: ListBroswer checkbox
mritter0 wrote:I would like to be able to enable/disable the checkboxes in a listbrowser node. Making it ReadOnly is not what I need. I still want to be able to select the item, just not change the checked state.
TAG_DONE);
Curious request. Why? Perhaps you need to investigate usage of labels and images if you just want to indicate the state of some flag.
It's perfectly possible to slecte a LBN without toggling the checkbox, simply by clicking on the label.
TAG_DONE);
RenderHook is your friend for all non standard rendering.
mritter0
Post by mritter0 »
It's not a matter of I don't want to accidentally click on the checkbox, I want to be able to toggle selection and toggle enabled/disabled state. Imagine a list of items and you need/want one to be forced on/off, but the item can still be selected, to show other things elsewhere. Pick this item, it forces that item on/off, so disable it so can't be altered until original item is toggled.
