Creating & writing to .adf & .hdf files
LoneHaranguer
Post by LoneHaranguer »
I have an AmigaOne X1000 running OS 4.1, and I have recently bought an FPGA Arcade Replay board.
The Arcade Replay when running an Amiga core can access .adf files and .hdf files. It can't access any other file type.
Is there a way to create these files and write to them under Amiga OS 4.x? I know that I could use WinUAE or Total Commander under Windows, but using a PC to allow one Amiga to communicate with another seems like giving up ...
javierdlr
Re: Creating & writing to .adf & .hdf files
Post by javierdlr »
For ADF try http://www.os4depot.net/index.php?funct ... device.lha
and maybe check aminet for some adf tools/commands (http://aminet.net/search?query=adf)
LoneHaranguer
Thanks. I'll give it a try.
salass00
Post by salass00 »
To create uninitialised .adf files you can use mkfile:
http://os4depot.net/index.php?function= ... mkfile.lha
In a CLI type:
mkfile blah.adf 880kb
Then mount it in diskimage.device in one of the IDFx: drives, do a quick format on the disk and then do whatever you want with it.
