frbuttonclass does not support GA_TextAttr
Or at least it isn't working for me here.
Any chance of this being added/fixed?
salass00
Re: frbuttonclass does not support GA_TextAttr
Post by salass00 »
chris wrote:Or at least it isn't working for me here.
If you use an IntuiText as the gadget label (GadgetText) then you should be able to specify a TextAttr using IntuiText->ITextFont.
Hmm, but doesn't the class convert GA_Text into IntuiText internally? In which case supporting GA_TextAttr should be trivial.
salass00
Post by salass00 »
chris wrote: Hmm, but doesn't the class convert GA_Text into IntuiText internally? In which case supporting GA_TextAttr should be trivial.
No, it simply puts the string directly in gadget->GadgetText and sets the GFLG_LABELSTRING flag in gadget->Flags.
To set an intui text label you should use GA_IntuiText.
