I entered the exact debug command for X1000 that's listed in the http://wiki.amigaos.net/wiki/Advanced_S ... ging_Guide WIKI which is:
setenv -p os4_commandline="serial munge debuglevel=4"
When I enter a printenv command I see this:
os4_commandline==
and the original setting is still shown as this:
os4commandline=DEBUGLEVEL=5 SERIAL
How do I get rid of the bad variable and set the correct variable?
CFE debug settings
CFE debug settings
Re: CFE debug settings
Faulty...
This one's correct:
you gotta lose the first "="setenv -p os4_commandline="serial munge debuglevel=4"
This one's correct:
...and to delete the other faulty var, just save a NULL/NADA/ZILCH/NOTHING in it:setenv -p os4_commandline "serial munge debuglevel=4"
edit: ...and yes, the wiki is wrong about the X1000 commandsetenv -p os4commandline
Thanks for the help. Hopefully someone will fix the WIKI.Raziel wrote:edit: ...and yes, the wiki is wrong about the X1000 command
@Raziel
This setting:
has been there since the day I received my X1000 from AmigaKit. I wonder how many other X1000 users have the wrong CFE OS4 commandline setting on their systems. The difference is easy to overlook since an underscore ( _ ) is the only difference. Maybe everyone should try entering "nvgetvar" in a shell to see if their settings are correct.
This setting:
While i think the wiki is a great place to roam through and find random information, i was never able to *really* find anything i was looking for.xenic wrote:@Raziel
This setting:
Whenever i used that dreaded "search" field it throwed things at me i didn't want to know.
I want a real "Contents" page, sorted by Alphabet, just like in the back of a DIY book.
(Especially when trying to script in AREXX the wiki is hell...i'm still using my dying printed AmigaOS 3.1 AREXX manual to do that)
The information about how to tweak my X1000 i took out of my X1000 "manual" (a few printed pages in a loose-leaf binder) i got with the machine (or, iirc, a few weeks after, after i bugged AmigaKit to send me one)
Thanks.ssolie wrote:Done.xenic wrote:Hopefully someone will fix the WIKI.
It's called an 'index' and I'd like to see the WIKI indexed too but I can't think of any simple way it could be done.Raziel wrote: I want a real "Contents" page, sorted by Alphabet, just like in the back of a DIY book.
How about All pagesxenic wrote:It's called an 'index' and I'd like to see the WIKI indexed too but I can't think of any simple way it could be done.Raziel wrote: I want a real "Contents" page, sorted by Alphabet, just like in the back of a DIY book.
That's more of an alphabetized table of contents but it's better than nothing.gazelle wrote: How about All pages
